yamahamaniac
- Jun 2, 2009
- Jackson's Arm, Newfoundland, Canada
Ok so say if I took the bearing off and the collar, then put the nut on, then bearing, then collar, would this work?
Not part of update. Bearing is identical.KEITHFD said:I'm just going by the list above;
Parts:
993306-20650 bearing (not cheap 6206 with a special Yamaha taper 30.1mm/31.1mm)
Should add up to about $50. That's what I paid for them new from dealer.8FA-17645-10 collar
8FA-17-642-00 nut
REDUNDANT.Two pieces the 03 did not have behind the secondary:
90201-25289 washer, plate
90209-25012 washer/spacer
Recall or not, has no effect on the bearings. It is your choice to change the bearings, but it is NOT APPROPRIATE to add in the price of the bearings to the "update" price.I'm definately doing the bearing as well as the bearing on the other side too. That's over $200 not counting the belt! Should have been a recall!
