Chris Hammer
- Dec 26, 2020
- Sydenham
- Rx Warrior 1000 cc LE 2004
Hi fellas and ladies, I have a 04 warrior, and the check engine light is on and the warning light is on steady and does not blink. Trying to clear the codes or figure out what is wrong but hitting a brick wall with the Yamaha manual. The only 2 wires I have left not hooked up at the handlebar is a blk and a yellow with a red stripe. I attached a pic for reference. Any help would be great.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
I can help with this, i know yellow w/ red stripe goes to yellow, i will be in the shop in the am& can check the otherHi fellas and ladies, I have a 04 warrior, and the check engine light is on and the warning light is on steady and does not blink. Trying to clear the codes or figure out what is wrong but hitting a brick wall with the Yamaha manual. The only 2 wires I have left not hooked up at the handlebar is a blk and a yellow with a red stripe. I attached a pic for reference. Any help would be great.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Sorry have been busy, do you still need help with your wiring?Hi fellas and ladies, I have a 04 warrior, and the check engine light is on and the warning light is on steady and does not blink. Trying to clear the codes or figure out what is wrong but hitting a brick wall with the Yamaha manual. The only 2 wires I have left not hooked up at the handlebar is a blk and a yellow with a red stripe. I attached a pic for reference. Any help would be great.
Chris Hammer
- Dec 26, 2020
- Sydenham
Hey @ Brotherdan, thanks, could still use the help. Almost done trying to restore this tank! If I had a pic of an rx1/warrior handlebars with wires I could probably follow it with no problem. The book gets to be hard to follow at times. My other harness burned up! Any help would be great.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Ok im not home but
will send you some clear pics later that i have on my old phone, i put newer apex bars on & have some good pics of original rx bar wiringHey @ Brotherdan, thanks, could still use the help. Almost done trying to restore this tank! If I had a pic of an rx1/warrior handlebars with wires I could probably follow it with no problem. The book gets to be hard to follow at times. My other harness burned up! Any help would be great.
Chris Hammer
- Dec 26, 2020
- Sydenham
Thanks, that would be great!
Brotherdan
- Sep 8, 2017
- Belmont,maine
Sorry for suchh a long delay, not sure how these will come out as i had to get them off an old phone, a few pics show an wxtra cord on the left side which was an rca helmet shield plug, also i converted to newer apex bars later on& added rocks yamaheater for better handwarmer grip heat, if you have any questions just holler& i will do mybedt to clarify,
Chris Hammer
- Dec 26, 2020
- Sydenham
Hi Dan, thanks for the pics!!! I see the one yellow wire with red stripe goes into the blk. I have to figure out the feed power wire which I am going to steal from the high beam wire and then find a ground. I will have to look at these closer on my pc as the phone makes it harder to follow. Where is your feed wire for the power coming from?
Brotherdan
- Sep 8, 2017
- Belmont,maine
Sorry the pics came out so bad, also its been awhile so excuse my mistake on the yellow/red wire, that is your power wire,see attached
Chris Hammer
- Dec 26, 2020
- Sydenham
Thanks brotherdan, I have no power off the yellow wire with the red stripe.... I am not sure where to begin to look at why it is not giving me any. I was told to go off my high beam wire for the headlight? I tried to zoom in on the pics here on my laptop but I might have to download them first. Hard to see on the phone as it's so small. I will see what happens. Hoping my throttle cable comes in tomorrow and I can at least drive it and see how it runs.
Chris Hammer
- Dec 26, 2020
- Sydenham
Thanks for the above help. I was able to finally get the hand warmers going, they needed the ground to complete the circuit! I am though having troubles with them and controlling the heat, got pretty warm and would not stay at the temp I set them at. Everytime I rode it got hot then popped a fuse. A good voltage regulator was put in and still gave me the warning light on the dash and check engine light.
