trosell14843
- Nov 17, 2014
- 2005 vector
Had no plan to pay $99 for the flap that brackets onto the frame that holds the snow flap on.
Soooo I looked at my 07 Apex looked just the same except the three bumps are not drilled out on the Apex one. I bought the Apex 8GH-77596-01 which fits just fine without the drilled out 3 humps. All drill holes and rivets are the same place. Bought the part at partzilla
Don't waste your money buy the $36 Apex part.
Only thing I see is the holes line up with some the tunnel protectors but I don't see why you would still have the stop attached if you're working in that area anyways.
Sent from my HTC6600LVW using Tapatalk
trosell14843
- Nov 17, 2014
- 2005 vector
By the way ya I painted the damn black gas cap that you can never seem to grab in the dark
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Barn of Parts also sells a stronger snow flap plate for $35. It has no indentations in it either, so less likely to accumulate more ice and snow which freezes in there.
trosell14843
- Nov 17, 2014
- 2005 vector
Good to know. Hope I never need another from a rear end impact
. I should always check with Travis furdt
