rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
ill be taking ou suspension soon. any way i can check to see it is where it should be? being that it looks rebuildable is it also pressurized? or should i just reinstall how it is?
there is no pressure in it. any seals are in there for grease retention.
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
ok so is there a way to test it when out?
it needs to slide back and forth by hand. if you cannot move by hand, it needs to come apart.
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
OK so more of a dampener then.
No its just like a transfer block but finer adjustments. Do you have a manual? Sag is measured at the rod with your spanner wrench which has a scale on it. But the sag is adjusted using the spring preload adjuster on the ONE main shock.
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
ok i have a general spanner i bought a while back but i think theres one in the sled kit also. ill wait till its back together and see if can get her to come up a bit
