rustinpeace
ill be taking ou suspension soon. any way i can check to see it is where it should be? being that it looks rebuildable is it also pressurized? or should i just reinstall how it is?
there is no pressure in it. any seals are in there for grease retention.
rustinpeace
ok so is there a way to test it when out?
it needs to slide back and forth by hand. if you cannot move by hand, it needs to come apart.
rustinpeace
OK so more of a dampener then.
No its just like a transfer block but finer adjustments. Do you have a manual? Sag is measured at the rod with your spanner wrench which has a scale on it. But the sag is adjusted using the spring preload adjuster on the ONE main shock.
rustinpeace
ok i have a general spanner i bought a while back but i think theres one in the sled kit also. ill wait till its back together and see if can get her to come up a bit
