Working on my buddies sled. He wanted to switch the track to a 2.86 pitch which necessitated a driver change. Actually we needed to change the front cooler and while we were under there decided to update track as well. Anywho. Pressed 8 tooth 2.86 wahl extrovert drivers onto existing driveshaft, installed with Ripsaw II 1.25" track. As the track turns (is tensioned, aligned) the track is hitting somewhere towards the front of the sled on what sounds like the protectors. The previous track was a ripsaw 1 with studs, this new track doesn't have studs. I am surprised the track lugs are touching the protectors... before I go digging in again, is this normal?
