06 Nytro oil leaking from PCV
Lakehouse2021
Age
57
Holly, MI
'95 Vmax 600
14 Skidoo Renegade X 1200
LOCATION
Holly, MI
New-to-me 06 Nytro- first 4s.... Go easy on me... :)
after some electrical issues solved, I hooked up the intake last night and have crank oil spue from from the nipple on the lower side of the crank housing. I'll call it the PCV but yamaha calls it the Crankcase breather hose. Did I make a rookie mistake? Have others seen this as well?
All hoses MUST be hooked up to the airbox.
You must have missed one if there's oil spewing out.
touche! I'm fairly certain that I screwed up the hose locations.... I wish the service docs did a better job of showing tube routing. They are good on my 95 vmax, but this machine, they suck.
I'm a D.A..... Must not have had lines completely correct. Changed filter and oil and reassembled and she is purring like a kitten! Thanks all
