06 Vector Suspension Knocking
Dipe06
Muncy, PA
When I go over bumps, mostly larger bumps, there is a knocking in the skid somewhere. It sounds like it's coming from the front of the skid.
I noticed that when I get off of the sled and look at the limiter strap, it is completely slack. Would this cause the suspension to knock? Is the shock spring set too low? Should I draw up the limiter strap?
What is the proper procedure to set the suspension up for me? I just got the sled and I've never been too familiar with adjusting suspensions.
Also, it might be in my head, but I think I notice it more when I'm accelerating mildly over bumps. Could it be something with the drive wheels?
The knocking is most likely the transfer rod. Won't hurt anything. Look at the top of this section and there is a sticky for Mono skid setup.
