06RSRAGE
- Jan 16, 2006
- Upstate NY (Colton)
- web.me.com
Has anybody had this happen? I don't think this happened on the ride I just took.. I did take a good hit about 3-4 rides back but nothing worse than I have hit with the old sleds. (I used to be able to teeter on rocks with the old POL)
And it just came back from the shop (Oil and filter change) (I would hope they would have told me) They are checking records and will call back.
yamaslob
Damn must of snagged a stump? I believe its about time to buy a skid plate also man.
-James
-James
06RSRAGE
- Jan 16, 2006
- web.me.com
06RSRAGE
- Jan 16, 2006
- web.me.com
Do they make a skid plates out of armor plate?
DoktorC
My RX has one of those...was there when I bought it...sucks notheless..
06RSRAGE
- Jan 16, 2006
- web.me.com
DC
Strangely enough that makes me feel better (Kind of)
DoktorC
Mine's actually worse...first thing I bought after seeing the damage was a skid plate. That little cardboard cover offers very little protection to the oil pan
06RSRAGE
- Jan 16, 2006
- web.me.com
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
FM got one on his rx last year only it bent the cooler too. never felt it in deep snow with stumps. He rides with a skid palte now. Maxdlx
yamaslob
Is the sled rideable?? What are you going to do? I would indeed invest in a skid plate its not a pain to take on and off for oil change.
Nitro blast
- Apr 2, 2005
I don't drive a rage but I ride a 06 nyto, first year out I didn't even feel a thing, but on a pre check before a ride I found all my oil on the deck of my trailor, I seams on the previous ride I must have hit something very litlty and taped one of the screws that hold the filter cover on and it pierced a hole in my oil pan,Yamaha covered this under warrenty and supplied me with a skid plate(nice people) they had to pull the motor to replace the oil pan ,I would recommend removing the screw that is in line with the oil pan and install a skid plate, there is very little clearence between the cover and the pan.
Nitro blast said:I don't drive a rage but I ride a 06 nyto, first year out I didn't even feel a thing, but on a pre check before a ride I found all my oil on the deck of my trailor, I seams on the previous ride I must have hit something very litlty and taped one of the screws that hold the filter cover on and it pierced a hole in my oil pan,Yamaha covered this under warrenty and supplied me with a skid plate(nice people) they had to pull the motor to replace the oil pan ,I would recommend removing the screw that is in line with the oil pan and install a skid plate, there is very little clearence between the cover and the pan.
I thought they have a dry sump oil resevoir?, so there would be no "pan"
the filter is right there, so that is reason enough to protect it w/a S P
06RSRAGE
- Jan 16, 2006
- web.me.com
Good on coolant I will check the oil. No vibrations or strange sounds when riding..
I will be having a SP put on soon
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Those yammy skid plates take a pretty good hit. I busted mine but if it wasn't on I would have had the same result.
06RSRAGE
- Jan 16, 2006
- web.me.com
I spoke with my dealer they said they had noted it when I had it in there and said they saw no leaks (They figured I knew it already) So that means it happened about 300 miles ago (that hard hit) and has been perfect since. I feel better now..
I asked the dealer to let me know anytime they note any dents even if they KNOW I KNOW already.
I ordered a black SP and it will be installed asap.
