rtx moose
- Jul 31, 2014
- WATERTOWN,MN
just tried to loosen my rear idlers to tighten my track and the nut snapped off taking the shaft with!!!!do i need to take out suspension to replace the shaft or can i slide a new shaft thru without?this is a ck skid not a mono
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Use a piece of rod, broomstick, whatever, and push the old axle out. The thing you use to push it out will keep everything aligned ish. No need to pull the skid out.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
X2Use a piece of rod, broomstick, whatever, and push the old axle out. The thing you use to push it out will keep everything aligned ish. No need to pull the skid out.
1/2 cooper pipe works well
x3 on not pulling the skid. you do need to back the track tension all the way off though. that shaft is the same back to the 1992 phazer II skid.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
So will the shaft from a 2000 srx fit in the ck skid?
yes it should.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
You can also knock the old shaft back a little and remove the roll pin that holds the bolt head to the shaft then use the new shaft to drive the old one out. Have removed this roll pin in the past to remove and replace the guide wheel right there behind the head side of the shaft on past sleds.
I had a center guide wheel go bad on a RX and wore a groove into a shaft and have kept that old shaft for a driving/holding tool.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Hey guys I'm in a serious pinch here is the shaft off my SRX skid going to work on this CK skid?
yes.
