OGGY DOGGY
Okay sorry but I have got to ask I want to do the secondary clutch mod on my 04 Griz . There seems to be some conflicting ways on how to do it, one says put a 1/2" spacer under the secondary spring,has anyone done this what are the pros and cons and where do you get the spacer? Oh and do you have to do mods to the primary clutch if you do the secondary mod?
OGGY DOGGY
Well I installed the 1/2" spacer,under the secondary spring ,I dont really notice it being faster on take off , but you do not even feel a lag when the clutch shifts.I took it on a short ride , in a couple of weeks we are going on a long cruise , the guys said take extra gas so I will really find out then how it works , I do notice that when you go into a corner let off and then on it out of the corner there is no lag at all. I think it is going to be beneficial to having bigger tires.
Grizzly450rdr
- Aug 22, 2007
What kinda space did you use??
Grizzly450rdr
- Aug 22, 2007
Sorry WHAT KINDA SPACER DID YOU USE???
steel is what I have... machined to fit under the cup ...
Grizzly450rdr
- Aug 22, 2007
Thanks for the help i took a piece of galvanized pipe and welded a big washer on it and it works perfect..
