langow
Just bought DTYA-1 weights, Daltaon Black/Green primary spring, and Black/orange secondary.
270hp tuned Sidewinder RTX -all groomed trail riding in UP of MI.
Do the DTYA-1's need weight added, or?
Does 6/2 sound correct for secondary wrap?
Thank you!
Thank you!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
6-2 is what Dalton recommends. Start with your weights empty, see what your rpm is at. Add weight accordingly. Adding weight trailside is easy with daltons.Just bought DTYA-1 weights, Daltaon Black/Green primary spring, and Black/orange secondary.
Thank
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
6/2 should be fine BUT.. Don't be afraid to try 6/3 with that blk/org. Few factors on the spring twist>track lug Hight, studs/traction..
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
6-1 vs 6-2 vs 6-3 whats does the spring wrapped tighter actually do?
I have a very similar clutch setup as the OP, same springs, same weights just add in all HD rollers, unfortunately I am a bit of a belt blower
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
The tighter wrap increases torsion (backwards tension) on the spring and clutch, gripping the belt tighter between the sheaves. 6-1 was the recommended wrap for the 1st Gen Dalton Black/Orange spring, the 2nd Gen Dalton Spring was 6-2 to get the same pressure. 6-3 would make it even tighter. There's a balance between going to tight though. Usually tighter means faster backshift and some loss of top end speed, all in the hopes of preventing belt slip.6-1 vs 6-2 vs 6-3 whats does the spring wrapped tighter actually do?
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Stock helix I assume? Wrap that spring to at least 6-2. I never ran the new black/orange spring, but I blew a lot of belts with the original black orange as it wasn’t stiff enough.
It’s easy to add weight to those daltons so I would try them empty first and see what RPM you turn.
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
Yes stock helix, i am running a lot of weight in the Daltons, sled makes good power, I will try wrapping tighter and see the difference!Stock helix I assume? Wrap that spring to at least 6-2. I never ran the new black/orange spring, but I blew a lot of belts with the original black orange as it wasn’t stiff enough.
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
Are you having issues with belt life or rpm’s?Yes stock helix, i am running a lot of weight in the Daltons, sled makes good power, I will try wrapping tighter and see the difference!
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
Belt life is my issue, I have the RPMs in check, lucky if I get 1000 miles with the Ultimax beltAre you having issues with belt life or rpm’s?
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
Do the springs wear out or are they good pretty indefinitely typically?
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
Springs wear out. 1000 miles isn’t too bad if you thrash on it all the time, but should get more. I run STM weights, so not an apples to apples comparison. These clutches need a lot of secondary spring I’ve found, I also changed my helix from stock to 41-37 on my brothers sled, and a 43/35 on my sled. Both 129s and both run hard with excellent belt life. I did 3200kms on one belt last season, and the belt still looks good.Do the springs wear out or are they good pretty indefinitely typically?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Primary clutch springs lose pressure although not too bad on Yamaha's, Ive never seen a Dalton or Yamaha secondary spring in a Yamaha secondary lose pressure. I check them on the scale ALL the time. When I ran my Doo's you really had to stay on top of spring to keep top performance and let me tell you the Doo's would lose pressure in a quick hurry. Primary and secondary springs.
- 7K
