mark53
I am thinking of installing 136 inch ice cobra 1.6 2ply
change the gear ratio to adjust the top speed
Merci pour vos très bons conseils
here normally there is a lot of snow
Tcat100
Get a whole shaft with drivers from a 2012 Arctic Cat procross. I did this and went to a 2.52 1" non quiet - much smoother and fasterif you have already done it
I want to change the pitch of my track for 2.52
I'm looking for the right number of parts for a jobber
so as not to make a mistake
DRIVE SPROCKET 10 TOOTH EXVOLUTE 2.52 PITCH
.purchase in canada wahl bros if availablewhich installs on for drive shaft 45mm 1.75 inches
thank you
ARCTIC CAT TRACK DRIVE,10T-HIGH PERF-ASSY
ARCTIC CAT TRACK DRIVE,10T-HIGH PERF-ASSY Part # 0728-201 Arctic Cat OEM Part
www.countrycat.com
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I switched from 141 to 144 so I could get an Ice Attack track, and get rid of the bearing slip by adding the shaft saver.
sideshowBob
How have you liked the Ice Attack on you Winder? I was not crazy about hookup on my 136" Attak with it.I switched from 141 to 144 so I could get an Ice Attack track, and get rid of the bearing slip by adding the shaft saver.
Any damage on exchangers ect from studs on that track?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
It's actually on a SRViper XTX, and I like it a lot. No problem with clearance or anything.How have you liked the Ice Attack on you Winder? I was not crazy about hookup on my 136" Attak with it.
mark53
thank you real professional what good advice
mark53
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Almost all of the Sidewinder LTX/SRX models that come through here get a 1.5, 1.6, or 1.75 lug track. Those tracks just fit our conditions better typically. Almost all of them then get switched from the stock 21/41 gearing to 24/50 gearing instead. The sleds are rockets 0-105 mph with these setups.
Trailleader
I think 2.86 rolls better
More gearing options for 2.52
NYTurbo
More gearing options ?I think 2.86 rolls better
- Apr 17, 2003
- Menno, SD
- Menno, SD
If you're looking for all out top end, the 2.52 is most efficient. The 2.86 or 3.0 pitch tracks are lighter simply because of less lugs in the equivalent track size.
NYTurbo
For sure.If you're looking for all out top end, the 2.52 is most efficient. The 2.86 or 3.0 pitch tracks are lighter simply because of less lugs in the equivalent track size.
Trailleader
The 2012 procross had 10 tooth 2.52 drivers and shaft is same so you can press those on also as an option.
Trailleader
As far as drivers go and sizesMore gearing options ?
Maybe that’s changed
Fleecer
- Jun 13, 2014
- 2019 SRX
Regardless of drivers, shafts are the same, so all gearing options are the same.As far as drivers go and sizes
- 36K
