14 VIPER STARTER IDLER GEAR REPLACEMENT!
Geez, the idea is to get the newer flashes BEFORE this happens.
I did not WANT the flash unless I had a reason that I needed it. Now I have a reason but I am still not enthused about getting it
Sounds like someone apposed to getting a vaccine for polio and doesn’t understand why you need it. Get the flash. Engineers much smarter than you and I have very good reasons for giving you a free flash. Do they screw it up? Sure sometimes they make mistakes but they can correct the issue with the next flash. Good luck with your repair.
Sounds like someone aposed to getting a vaccine for polio and doesn’t understand why you need it. Get the flash. Engineers much smarter than you and I have very good reasons for giving you a free flash. Do they screw it up? Sure sometimes they make mistakes but they can correct the issue with the next flash. Good luck with your repair.
If they were really that smart, there wouldn't have been so many updated flashes so far and they would have gotten it right the first time like the Nytro & Vector.
