shortstop20
Looking to find out the TRUE dry weights of the 2003 and 2004 RX-1. Not Yamaha numbers. Any help is appreciated.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
my 03 rx1 out of the crate was 609lbs.
check this:
http://www.ty4stroke.com/viewtopic.php? ... ght=weight
check this:
shortstop20
Do the 4 strokes come with oil and coolant in them from the factory? Because I saw in SRXspec's post that he said the RX-1 was 605 pounds.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Yes oil & coolant is full, those weights were with everything except gas. All oil, coolant, and battery was installed & filled to correct level.
shortstop20
That's what I figured, thanks Allen. Some guy on HCS is throwing a hissy fit because I told him the '03 RX-1 was 600 pounds.
http://www.hardcoresledder.com/forums/i ... 557&st=255
