03RX1-ER-LE said:Owning three of these sleds I can say this is normal. I had a Viper, V-max's and Phasers and they all do it. The RX has even more tie rods and off-set shafts then other models. Have never replaced a tie-rod yet on my sleds, has anyone else replaced any? Did replace a tie rod on my grandson's 85 Bravo for slop, did not make any difference in slop.
MotoPsycho said:apltx08 said:ULMER racing...
...excessive VIBRATION was being transfered threw the SOLID type/style set-up...
That particular statement is actually a falicy, concockted from mis-information, differing circumstances, and a completely different set-up.
Mr. Ulmer himself has ordered our bushings to install on his customers sleds. There is no noticeable increase in vibration transfer with our bushings through testing, riding trials, and customer feedback.
As a matter of fact, our bushings are being used by a select few Team Thunderstruck riders with excellent feedback, and performance results...
The beauty of it is; you never have to lube our bushings, and if you have an underhood turbo, they will never melt!
But, alas... to each their own. I just thought I would set the record straight. Thanks for your time!
CHEERS!
-Moto
sobfrogg said:MotoPsycho said:apltx08 said:ULMER racing...
CHEERS!
-Moto
After a few fiends over on SNOWEST recomended them I will be ordering them for both of my tons.
I have tried tightening the stock blocks by removing some material from the stock bushings and blocks. Got rid of the slop for the first ride. Then sloppy again. Solid blocks should last longer.
