2006 Apex ER Exhaust
curtis.venne
Hey, as per my previous post, my driveshaft bearing went and while it was being replaced the mechanic started up the sled and noticed it being extra loud. Turn out i have a hole in the exhaust pipe underneath the seat. i thought i read somewhere that this was a recall or something similar. Can anyone shed light on that?
Yes warrenty issue on donuts and pipes.
I picked up a used attack that the own showed my a recipt from a dealer replacing the entire system but the rear can.
I had mine welded. I had my sled on an open trailer. I dropped the rear of the suspension, and the welder had access to the exhaust. He lifted the rear of sled on a chain fall.
curtis.venne said:
But does Yamaha cover any of the cost or if its out of warranty you are pretty much on your own?
TurboTime said:
No recall. Just needs to be replaced or welded..
I have not heard of this being covered under waranty but if it is still under Y.E.S. its worth a try take it to a dealer.
