brad14880
- Oct 12, 2012
2006 rtx 4400 miles on it. the rear skid is smoked, the hyfax is real thin just about every idler wheel is toasted, the top of the shock towards the front has been worn down by the track rubbing on it. what are my best options for replacement, buy another skid or rebuild this one, and what might cause this to do this.... PLEASE help
Dreams_of_Apex
- Dec 26, 2012
- Ottawa/West Carleton, Ont
- www.facebook.com
- 2012 Summit SP 800r ETEC.
Rebuild would likely be cheaper than a new skid, and have heard that the Mono Skid is great skid, esp when shocks are revalved. Sounds like you would need shock maintenance, so might as well have it rebuild and revalved.
But all depends what you want, and your budget.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
depending on how much the shock is worn down...you can use the shock saver that ulmer sells...and add your new slides and wheels...not a biggie
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
If you rebuild the shock, new slides, idler wheels your probably in the $500-600 range. Hopefully your arms are not cracked or you will need the beef up kit which is another $200+, then hope your rails are good.
All in all the mono well set up is a decent skid once you do the beef up kit and revalve to fit your weight and riding style.
To replace with something superior like a ZX2, M10, etc is going to set you back $2000
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
RTx is more rugged than mono...no need to beef up...havre carver revalve...wheels cheap. slides cheap..
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
ah if it hasn't broke tubes..you can gusset and werks yourself...thats cost effective...most likely need new bushings...Ive heard negative things about the zx2...sounds like a big investment..
brad14880
- Oct 12, 2012
There is one crack at top.of. front pivot arm. It can be weldedbut wwhere to goto buy replacement parts
apex55
apex55
or rebuild it here:
http://www.ty4stroke.com/viewtopic.php?t=74254
brad14880
- Oct 12, 2012
Okay 265 in wheels and sliders and who knows what pioneer is gonna cost me.replaced every wheel and bushing so far. Had a crack in the top of front pivot arm. Grinded it down and rewelded it good to go with it thus far.
- 29K
