yamadog07
are suggesting to replace check or take out & clean/free up ?
02xtreme
Checked mine and flow was same with and without check valve. Mine idles low after I've been riding for a bit and come to a stop and let it idle. If I shut the sled off and start it up again it usually idles as the normal 1500rpm.
lawmanbsi
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
yamadog07 said:are suggesting to replace check or take out & clean/free up ?
Just check and clean. Make sure gas flows through freely. May not be your issue but good to rule out.
tomanytoyz
At this mileage im sure you have some carbon build up in the engine,more then when it was newer..try doing a de-carbonizing. yamaha and also sea-foam have some liquids that will help.worth a try..
- 148K
