Thor17
- Feb 27, 2010
How’s it going? I recently purchased a 07 phazer gt for my son. The reverse was working intermittently and now it doesn’t work at all. I push the button and nothing happens no buzzer and no indicator light. This is my first Yamaha so I’m not very familiar with them. Any help would be appreciated thanks
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
When warmed up the idle speed should be around 1,800 rpm. If it's much higher the ECU doesn't usually allow reverse to function. One of mine had this exact issue when I bought it and turning down the idle cured that one.
Thor17
- Feb 27, 2010
I’ll have to see what idle speed is when I get off work
is the indicator on the gauge flashing after you push the button?
Thor17
- Feb 27, 2010
No the light isn’t flashing. The light doesn’t turn on at allis the indicator on the gauge flashing after you push the button?
Thor17
- Feb 27, 2010
Idle speed is around 1600 give or take 20 rpm when warmed up…still no reverseWhen warmed up the idle speed should be around 1,800 rpm. If it's much higher the ECU doesn't usually allow reverse to function. One of mine had this exact issue when I bought it and turning down the idle cured that one.
YukonMP
- Dec 25, 2014
- Yukon Territory
There are several threads dealing with this issue in the Phazer FAQ section.
To tell you the truth every time I think I have this figured out it stops working reliably again and that is after 16500kms.
Thor17
- Feb 27, 2010
I’ve done a quick search and read some of the threads dealing with this annoying reverse problem but didn’t really find anything like my problem….with no indicator light at all.There are several threads dealing with this issue in the Phazer FAQ section.
make sure all the plugs are clean and pushed together. sounding like one might have corrosion.
YukonMP
- Dec 25, 2014
- Yukon Territory
I've just had a look also and couldn't find the thread/posts that I had in mind. I think it was Mooseman that was running into this. He's bound to show up here before long.I’ve done a quick search and read some of the threads dealing with this annoying reverse problem but didn’t really find anything like my problem….with no indicator light at all.
turbogts22
- Jan 16, 2021
I'm wondering if the throttle safety switch plays a roll in this function. If for some reason the switch is stuck on when the throttle is released does the ECU lock out changing gears? I'll have to experiment on mine to find out.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Try this. Turn the key and start the engine, Dont pause to hear the fuel pump. Mine would not go into reverse sometimes - same as yours. But it you start it that way it will always go into reverse. At least for me.
YukonMP
- Dec 25, 2014
- Yukon Territory
Likewise here, if I pushed the reverse button immediately upon start up it would sometimes take reverse ... but not always.
turbogts22
- Jan 16, 2021
I did just verify that any small amount of throttle input locks out the reverse button function. Too high of a TPS reading at idle may even cause it if that is out of adjustment. These things are fussy if anything is out of spec. Both of mine had reverse issues till I took the time to sort them out. They've both been trouble free for over 2,500 miles since, fingers crossed.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
You rang?Mooseman that was running into this. He's bound to show up here before long.
I never was able to find the cause of this problem, which is the infamous 'push the button and nothing happens'. Seems to be associated to the flashing green D light but that too there is no known cause. Mine would flash when I decelerated. All I could do, as indicated above, was to restart the engine, going straight from OFF to CRANK. It somehow bypasses whatever safety it's enforcing.
