message sentVip now...would love a manual
goto802
Update she has ignition..3 coils...2 open and 1 .20 ohms on primary circuit...idk...just what I found..also start stop switch faulty.bypassed that....now fires with external fuel.....will not draw fuel into engine...thinking needs to have airbox on as I covered one carb with my hand and she fired for a sec...
Yes. Needs air box but check fuel pumps when firing for flow.Update she has ignition..3 coils...2 open and 1 .20 ohms on primary circuit...idk...just what I found..also start stop switch faulty.bypassed that....now fires with external fuel.....will not draw fuel into engine...thinking needs to have airbox on as I covered one carb with my hand and she fired for a sec...
goto802
So btw she is an 07 my mistake....how exact are the timing marks on these 900s? If it was a car I would condemn the chain...cams are lined up perfectly and crank is off....crank is lined up and intake cam off maybe half a tooth
Post a pic, they are damn close.So btw she is an 07 my mistake....how exact are the timing marks on these 900s? If it was a car I would condemn the chain...cams are lined up perfectly and crank is off....crank is lined up and intake cam off maybe half a tooth
