Aaron hagen
- Oct 12, 2017
- Red Deer County
- 2008 phaser 500
Hello everyone
The boy got stuck at the end of the season last year and code 13 won't clear, not to sure what I'm looking for other than intake pressure sensor or circuit problem on cylinder #1 where do I start? Thanks
Look to be sure the hose underneath sensor is still connected.
Aaron hagen
- Oct 12, 2017
- Red Deer County
- 2008 phaser 500
Ok will do thanks.
Aaron hagen
- Oct 12, 2017
- Red Deer County
- 2008 phaser 500
Found all connections to be good did reset through diagnostics feature also disconnected the battery for 10 mins and now code 84 is also up TORS anymore ideas?Thanks
2008lee
- Apr 21, 2016
- vanderhoof
- 2008 phazer mtx 151
I had a broken wire for the sensor twice last winter. I finally removed the sensors from the air box and fastened them to the fuel rail.
The air box resonates with the intake pulses and shakes the sensors and wires to death.
Aaron hagen
- Oct 12, 2017
- Red Deer County
- 2008 phaser 500
Yup found the broken wire it's 2mm from the connector thanks now did you replace the whole wiring harness or were you able to splice the wire?
2008lee
- Apr 21, 2016
- vanderhoof
I was able to splice it or something I cant quite remember.
Aaron hagen
- Oct 12, 2017
- Red Deer County
- 2008 phaser 500
Ok thank you.
PhazerSD
- Nov 17, 2019
- WestSide Canada
- 2014 Yamaha Phazer
2011 Yamaha RS Venture
Just went through something similar, have a look at this thread that I've updated with aftermarket harness parts I purchased and installed:
https://ty4stroke.com/threads/air-intake-pressure-sensor-problems.96796/
Dave hache
- Dec 27, 2019
- 2008 phazer 500
How do I make a post having stator problems on 2008 phazerI was able to splice it or something I cant quite remember.
PhazerSD
- Nov 17, 2019
- WestSide Canada
Go to the main Phazer discussion forum : https://ty4stroke.com/forums/phazer-phazer-mtn-general-talk.54/How do I make a post having stator problems on 2008 phazer
Upper right side, there is a search bar. Search for Stator. This will only search the Phazer threads. If you cannot find what you need, there is a button near the search bar labelled: "Post New Thread"
- 57K
