2009 Yamaha Nytro XTX 144" Build/MOD
Yeah i still need to finish the other side. My drill went dead lol
sent using my personal communication device
Ha damn power tools. When you need them the most they don't work or wont fit where you need them.
Decided to use the coolant line block off as the route for the wiring for the tail light.
Drilled a hole for the wires to run through the end of the cap.
What it looks like installed
I tried to use existing rivet locations as much as possible to keep the outside as stock and uncluttered as possible.
Halfway run. Still need to figure out what to do at the end by the tail light.
i just ran my Ptex all the way to the back (no turn) and left the wires exposed with just the black cover on them from the light to the side of the tunnel, i know its not the cleanest but i didn't want to buy an elbow for the pipe. i also reasoned this by saying that the pipe would give more room for snow and ice to collect on top (even though its smooth) as opposed to having 3 small wires wrapped in smaller protection that is rougher in texture. I am going to keep an eye on it to see if ice builds up.
My other option was to have to pipe bend out towards the hole where the light is if you can find rivets that line up and your exhaust wont be in the way.
Decided to cut the pipe short and finish the rest with heat shrink tube once I am ready. I filled the end of the pex with 100% silicone to keep elements out.
Got the front end fully assembled and put the skis on. Starting to look like a sled again!
Got the nose pan and front bumper back on! Loving the new front end.
Got the final polish done on the tunnel today also.
Christmas time!! Just got my early present from UPS tonight. Found this 2" challenger track for 250 shipped. 2 lugs missing but nothing major.
Got the exhaust finished and painted with ceramic high temp paint. All installed.
where is the muffler I gave you for this project?
It ended up not working for what I needed it for so I gave it to a friend that has a crotch rocket
Got the taillight wired up and rear bumper and snow flap installed
Where did you get the tail light?
Sent from my SM-G920W8 using Tapatalk
