jbassett79
- Jan 9, 2021
- Colorado
- 2010 Venture lite
The stop switch is even easier. Just jump the two wires together, Brown and Brown/White.
ok then yes I did try and jump them that way to see if power would come on.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Is there power at the switches? With key off, there should be power only to the Red/Yellow wire at the key switch and in Run, there should be power on the Red/Yellow and Brown wires at the key switch and at the kill switch on the Brown and Black/White wires.
Sounds like you have a wire break somewhere.
jbassett79
- Jan 9, 2021
- Colorado
- 2010 Venture lite
I have tried that a few different times even replaced it
jbassett79
- Jan 9, 2021
- Colorado
- 2010 Venture lite
I will check again for power at the switches when i get home. That is what I'm afraid of is a wire break. I haven't seen anything that sticks out but thats not to say there isnt still a broken spot.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Did you try the above?
jbassett79
- Jan 9, 2021
- Colorado
- 2010 Venture lite
I just picked up my new relays. I tested a couple that were bad. I'm going to put them in and give it a whirl tonight
jbassett79
- Jan 9, 2021
- Colorado
- 2010 Venture lite
At the connector for the key there appears to be slight power it is all millivolt and jumps around like crazy. I just put in the new relays and made sure the battery was fully charged
jbassett79
- Jan 9, 2021
- Colorado
- 2010 Venture lite
Okay better explanation. With the key off I gets sporadic readings at the red/yellow wire for the key. With the key in the on position both the red/yellow, and brown wires go to zero.
jbassett79
- Jan 9, 2021
- Colorado
- 2010 Venture lite
After replacing all relays, going through the wire loom again to find a pulled ground out of some ground connection, and another burned fuse. Not to mention hair color and some beers. It is now running! Not sure what step actually was the problem, but now i know a little more about the machine. THANK YOU EVERYONE for suggestions and help.
- 6K
- 8K
