pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
First EPS issue I've ever read about and it's over at no cost to the owner. SWEET!
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Can I ask what connector you found loose? mine is still the same after replacing motor and controller.Well, I fixed it. Feel a little stupid, one of the connectors worked loose. Guessing diagnostics wouldn't work because there was no signal at all to the controller. Either way, everything is cleaned, dielectric grease on all connectors, and now I am sure things are TIGHT thanks for the help everyone!
viperaddict
- Sep 6, 2004
- Alton NH
- 2003 viper w/monoshock and simmons skis
2011 apex SE
Large black one in the noseCan I ask what connector you found loose? mine is still the same after replacing motor and controller.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
ok, Thanks.Large black one in the nose
Scott Weeks
- Jan 3, 2020
- Maine
- 2014 Apex XTX
2011 Apex XTX
2005 Vector
2005 RX1
What and where were the connections that came loose? I have a 2014 with exact same issue. Thank You
RobX-1
- Coldwater, OH
I believe he was referring the power steering control unit #35:
viperaddict
- Sep 6, 2004
- Alton NH
2011 apex SE
That's exactly right, they are up in the nose with that clear-ish rubber boot covering then
Scott Weeks
- Jan 3, 2020
- Maine
- 2014 Apex XTX
2011 Apex XTX
2005 Vector
2005 RX1
I have a 2014 same issue. Where was the connector that was loose? I took apart,cleaned and applied dielectric to every plug in front nose of the sled as well as cleaned that obvious ground. Getting pretty frustratedWell, I fixed it. Feel a little stupid, one of the connectors worked loose. Guessing diagnostics wouldn't work because there was no signal at all to the controller. Either way, everything is cleaned, dielectric grease on all connectors, and now I am sure things are TIGHT thanks for the help everyone!
viperaddict
- Sep 6, 2004
- Alton NH
2011 apex SE
I think it was this here, if I'm remembering correctly.I have a 2014 same issue. Where was the connector that was loose? I took apart,cleaned and applied dielectric to every plug in front nose of the sled as well as cleaned that obvious ground. Getting pretty frustrated
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
I replaced the Stator in mine to fix my EPS problems.
viperaddict
- Sep 6, 2004
- Alton NH
2011 apex SE
Was the EPS not working the only symptom?I replaced the Stator in mine to fix my EPS problems.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Yes, EPS light would come on 1or 2 miles down the trail, stay on until you did a key cycle, replaced the module and the steering motor still the same problem until I replace the stator all good now. Stator was putting out 12.2 v now its over 14vWas the EPS not working the only symptom?
Scott Weeks
- Jan 3, 2020
- Maine
- 2014 Apex XTX
2011 Apex XTX
2005 Vector
2005 RX1
How did you test it to confirm that was the issue? I tried testing the plug that goes into the regulator out of the stator with it running but couldn’t get a readingI replaced the Stator in mine to fix my EPS problems.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
positive and negative battery terminals.How did you test it to confirm that was the issue? I tried testing the plug that goes into the regulator out of the stator with it running but couldn’t get a reading
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
I’ve heard of EPS issues with weak batteries as well, one dead cell causes “strain” on the stator output and there’s just enough voltage drop to pop the EPS telltale and disable the system. I’m willing to bet this is the main factor with EPS sleds having initial inop function on extremely cold days as well. Once the drained down battery recovers sufficiently and vehicle voltage stabilizes the EPS system starts to work normally again.
- 7K
