viperaddict
- Sep 6, 2004
- Alton NH
- 2003 viper w/monoshock and simmons skis
2011 apex SE
My father in laws apex handwarmer switch has seemed to fail. The grips still warm but the rocker switch wont adjust them. Anyone had this happen before? Wondering where to start. We did check for corrosion and the connector and it seems fine. Thanks!
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Replace the rocker switch.
viperaddict
- Sep 6, 2004
- Alton NH
2011 apex SE
I assumed that might be the answer, common occurrence?Replace the rocker switch.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
I replaced one on a customers Apex, I don't need the handwarmers on my Apex.I assumed that might be the answer, common occurrence?
or you could take apart the handwarmer switch and clean the contacts. had to do that before on my toys.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Ditto. Did that on my RS GT. Parts inside are small though but doable. Get a can of DeoxIT. expensive but works a treat.or you could take apart the handwarmer switch and clean the contacts. had to do that before on my toys.
RobX-1
- Coldwater, OH
Mooseman, is this the stuff you're talking about; can on the right? I've always used the stuff on the left but the reviews on this DeoxIT are pretty good:
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Yep, that's the one.
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1981 ET340 "Frankenticer"
1982 SS540
1981 ET250 Mod Oval/Lemans Racer
Anyone have a how-to on disassembling the switches? On my 2013 Apex
I have one that I have to press hard to lower the handwarmers. Thinking it just needs to be cleaned.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Yep, same thing as me. It's pretty evident how it comes apart however just be careful not to drop the little metal contacts and do it over a table. They are small.
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
Ditto 2 on cleaning the switch contacts. Did it on my Vector a long time ago. What you use is less important than the cleaning itself. Be sure to rub the contacts with a q-tip or micro fiber and not just spray them. Isopropyl is fine for this too.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Mine stick a little. Meaning sometimes they don’t increment. Then they do. I would replace or clean switch when they stop working. For me my Motec controls them in the software, and I find that one setting generally works so I may not even need my switches lol
viperaddict
- Sep 6, 2004
- Alton NH
2011 apex SE
Thanks guys, I'll take apart and clean them up!
Caveman
- Sep 13, 2012
- New Hampshire
- Yamaha, Polaris, SkiDoo.
I thought my left switch was bad last season on my 2012 and was ready to replace and it ended up being a bad stator. Once the stator starts to go, the handwarmer switches do crazy things, not enough voltage and start to jump around. On another sled (Vector), cleaning them never worked, just replace the whole switch.
viperaddict
- Sep 6, 2004
- Alton NH
2011 apex SE
Good info, thanksI thought my left switch was bad last season on my 2012 and was ready to replace and it ended up being a bad stator. Once the stator starts to go, the handwarmer switches do crazy things, not enough voltage and start to jump around. On another sled (Vector), cleaning them never worked, just replace the whole switch.
