ksblock
- Mar 22, 2019
- MN
- 2012 rsventureGT
Take spring out of primary put cover back on and see if clutch slides in and out easy or hard, had an 05 venture that slid hard and felt no matter how i clutched it it would bind and slip when going slow, only fix would be softer belt and more aggressive curve on weights and14.5 rollers to get better squeeze on belt at slow speeds, the stock flat profile weights are not good for bottom end grip, can also try lower rate spring for more grip, just a few things to try if all else is good
ksblock
- Mar 22, 2019
- MN
- 2012 rsventureGT
So took the time and cleaned up the clutch today, it was a little dirty but nothing bad. Checked the sheave faces for wear abd they look good. The movable part of the primary seamed to slide Easy. Rode it around the yard with cover off for about a minute and the primary sheave inside clutch was too to touch.
How do I get more clamping pressure out of the primary? Thanks in advance
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I still have the original belt on my 2011 Venture GT with 3K miles, something is not right with your alignment would be my guess.
ksblock
- Mar 22, 2019
- MN
- 2012 rsventureGT
Alignment checks out,I still have the original belt on my 2011 Venture GT with 3K miles, something is not right with your alignment would be my guess.
LOL, you are asking for a blown belt at that mileage..
ksblock
- Mar 22, 2019
- MN
- 2012 rsventureGT
Gotta buddy at work that gave me his belt off his sled that had over 10k on it. Changed it because he wanted to. Same sled as mine just older.LOL, you are asking for a blown belt at that mileage..
After about 3500 miles they start to dry rot and will de-laminate from the heat of driving them hard. I dont personally care how long people want to run the belt, I know based on mileage what kind of mess it makes when it blows. I just shake my head as I drive buy, guys that want to save a buck, enjoy.
if you sled is blowing belts, you have alignment or clutch issues for sure.. ask @Thunder Products
ksblock
- Mar 22, 2019
- MN
- 2012 rsventureGT
Trust me I understand the mess and destruction. Had a belt blow on my old Xc and it hit so hard it broke my toe!if you sled is blowing belts, you have alignment or clutch issues for sure.. ask @Thunder Products
ksblock
- Mar 22, 2019
- MN
- 2012 rsventureGT
drill the head off and pop them out with a punch.
ksblock
- Mar 22, 2019
- MN
- 2012 rsventureGT
I guess I didn’t explain what I was looking for. River removal will decrease clamping force?drill the head off and pop them out with a punch.
yamadoo
- Jun 3, 2003
Yea it might be time, but that sled gets pampered on local Burger rides. But your your probably right its time.LOL, you are asking for a blown belt at that mileage..
