2012 Yamaha's
striperpro said:
I'd like to c some of there 4 stroke outboard engines in a sled. V-6 300 HP.make it light and handle like on rails and ill buy one
They can't even make their 2 cylinder with 80hp do that. :drink:
low slung said:
http://ip.com/patent/US7523799
A mono for the Phazer, I wonder if it will have a smaller engine without the gear reduction. It migth make the Phazer as ligth as it should have been from start.
Comatoast said:
Whens the release on the 2012s again?
Doo just showed their 2012 line.. What a snoozefest.. It was just a preview as the full line up will be released tomorrow , But wow.. Disappointing
http://www.dootalk.com/content/showarticle.php?ID=81
I was kind of hoping to see a new lighter 4 stroke in their lineup.
It's like the release Yamaha had last year, first ones to show their lineup and the only new thing was power steering.
Are we just expecting too much of the OEMs to wow us each year?...probably.
I think so too. Personally, I'd rather see them come out with nice sleds that I didn't think were worn out after 2 or 3 seasons.
I'd be shocked if Yamaha came out with anything groundbreaking much less a 2 stroke. The backbone of their product is the 4 stroke. Arctic Cat on the other hand, is a different story. :drink: :bling I learned my lesson with the 08 Nytro, don't buy a radical first year sled.
i dont understand y yamaha doesnt come out with valve lift in thier motors. yamaha made engines for the Toyota xrs and matrix and pontiac vibes and when the oil pressure reached a certain psi a new roller would open causing the valves to open longer creating more power on top. down fall is that this does not make torque. but the valve lift would be like power valves on a 2 stroke. so u use the torque down low to get u up to speed then make a but load of power with the lift and get this motor in a more balanced chassis. i wish they would do that.
EXCITER
VECTOR CHASSIS WITH PHAZER MOTOR AND A SUPERCHARGER TO MAKE 110HP. THINK ABOUT IT, 2 CYLINDER AND LOTS OF ROOM FOR A SUPERCHARGER AND POWERSTEERING. 55LBS LIGHTER THAN A VECTOR.
NEW NAME IS EXCITER.
A Snoozefest? They are bringing out a new rear skid, which is pretty serious business. Wait til Feb 28 intro of the new yamahas, I hope I'm wrong but I fear that might be the real disappointment. LaLaLa
Re: EXCITER
Sounds great! What do you think it will cost?
