2013 VK Pro replaced battery and now won't start
Maine
2013 RS Viking Professional
Got my first sled. 2013 RS Viking Professional. Sat for 2 years. Put new battery in and still won't start. Does the hose closest to the front just hang down, i didn't notice it until I removed the air box, and cannot see anything obvious that it connects too? Thanks
You may be referring to the vent hose that does not hook up to anything. I just sits in the airbox. Look inside the airbox for a two fingered clamp/holder that it just presses into.
If that is what it is then it will not fix your starting problem. What is it doing? Codes?
fuel injected or carb?
if injected, make sure fuel pump is working.
if carb, you will have to pressurize the fuel tank to get gas to the pumps/carbs or fill the carb bowls through the vents with gas or crank for a realllllly long time.
does it cough with either sprayed into the air box while cranking?
