dennis42
- Feb 7, 2023
- Minneapolis
- 2015 Viper
I brought my Viper into a local powersports repair shop to check on a coolant leak. That has been resolved, however, he said the battery went dead. He charged battery and now it will not start -- the engine cranks but the fuel pump does not cycle. He said he did some "calling around" and claims the sled needs to go to a Yamaha dealer to be "reset"?? That sounds crazy. Any thoughts??
LOL, I dont think so.. I would guess the relay is stuck or the kill switch is on.I brought my Viper into a local powersports repair shop to check on a coolant leak. That has been resolved, however, he said the battery went dead. He charged battery and now it will not start -- the engine cranks but the fuel pump does not cycle. He said he did some "calling around" and claims the sled needs to go to a Yamaha dealer to be "reset"?? That sounds crazy. Any thoughts??
dennis42
- Feb 7, 2023
- Minneapolis
- 2015 Viper
Thanks for the quick feedback. Will the engine turn over if the kill switch is depressed (in kill position)? It's a new sled to me - I've only owned Ski Doo's prior this.
Yes if the kill switched is rocked forward it will crank and not fire.. stupidest thing they have ever done.Thanks for the quick feedback. Will the engine turn over if the kill switch is depressed (in kill position)? It's a new sled to me - I've only owned Ski Doo's prior this.
dennis42
- Feb 7, 2023
- Minneapolis
- 2015 Viper
Apologies for the delayed follow-up....I took my sled into a Yamaha dealer. They spent 3 hours troubleshooting the issue and determined it was the ECU. $1200 and 3 months later and the issue was resolved (season was over so didn't get to ride it any material distance).
Wow that’s insane!!Apologies for the delayed follow-up....I took my sled into a Yamaha dealer. They spent 3 hours troubleshooting the issue and determined it was the ECU. $1200 and 3 months later and the issue was resolved (season was over so didn't get to ride it any material distance).
Viper_Dean
- Sep 10, 2019
- Twin Cities
- 2014 Viper RTX SE
Not sure where in the cities you are, but I highly recommend taking your Viper to Century Powersports in Stillwater. Their service group is awesome and always takes great care of me.Apologies for the delayed follow-up....I took my sled into a Yamaha dealer. They spent 3 hours troubleshooting the issue and determined it was the ECU. $1200 and 3 months later and the issue was resolved (season was over so didn't get to ride it any material distance).
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Just a thought but when you had the coolant leak repaired was there any welding involved. The high frequency from tig welding will play hell with the electronics. When ever welding on these sleds always unplug electronics, disconnect battery and place ground clamp as close to weld area as possible.
