Snowmobile Mike
- Oct 19, 2018
- East Haven Connecticut
- 2016 Yamaha XT SE
Just purchased 2016 Viper xtx se, it only has 143 miles on it, it's been sitting for over a year, I have all panels off in front to do TLC on it. Everything works, I have air box off and have made cut out also cleaned up sled ! One problem mice were just starting to get in there,small nest near nose, like I said Everything WORKS and no nibbles on hoses or wires ! They enjoyed the black felt NOT THE FOAM under felt on the can side. Does anybody know where I can by this TYPE of felt ? To me that felt seems to help with sound deadening but most importantly protection from Can to panel ! Yamaha parts list call it damper . It seems they only sell foam and felt as one pc, I would then have to remove foam / felt from panel, that I'm sure is no picnic ! This felt / heat protection is about a lite 1/4 inch thick. I have about 5 pcs affected on can side so to avoid the monies the time and effort, I'd like to see if anyone knows where I can buy this type of felt in like a 2 ft x 2 ft sheet. Or any other way you guys might suggest to treat foam on can side without removing foam? Felt just peels off hoping to just glue new felt on! I gonna at least try before I buy 5 damper pcs. THANKS
Guys.
Guys.
I have never seen it sold separately.
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
I have found a felt site, maybe on to the correct path , anybody else have this kind of issue with Mice ?
Yes. The buggers did same thing to my RR. Could see the teeth width carvings all over just the black felt stuff. Never found where they made the nest out of it. Now once in awhile I put a 5 gallon bucket 1/2 full of water and birdseed sprinkled on top. 2x4 from ground up to bucket and hanging over water. Drowns the buggers by the dozens! Very satisfying.I have found a felt site, maybe on to the correct path , anybody else have this kind of issue with Mice ?
My Viper stays in garage so no mice. Cats in shed all summer.
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
The felt store seems to have correct material, emailed them, about possibly different thickness
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
HANSWAY High Temp 18"x24"x1/8 carbon fiber welding blanket Amazon $9.99 ,I ordered this it should work I hope. Free ship with Prime. The felt store has it , similar 12"x12" ,to small though like $9.99 plus $6.00 ship or like $58.00 for 3 ft x6 ft plus ship forget that ! In case those buggers got at your felt !
Mike I changed title to make it easier to find. Will put this in FAQ. Thanks for your research! Now kill those mice.
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
I pulled almost all the insulation and felt out of my sled. I left some near the exhaust but that’s it. I opened all the vent holes up (very carefully) with a brand new hacknsaw blade and then cleaned the cuts up with a sharp razor blade. My sled runs much cooler now. It’s much easier for cold air to move in and hot air to move out.
lanyard3
- Oct 2, 2014
- 2015 SR Viper RTX SE
I also had a mouse make a nest out of some of my felt. Only good thing is I found it drowned in the dogs water bucket.
Thanks for the idea of what to order but what kind of glue do you think will work best? Thanks!
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
When material comes in I will look into what glue works best to attach felt to foam,I will check back here.I also had a mouse make a nest out of some of my felt. Only good thing is I found it drowned in the dogs water bucket.
lanyard3
- Oct 2, 2014
OK, thanks!
