Ok, I’ll let you know after this weekend how many harnesses I have left. I can always get more plugs and do a few more.I would be interested in the harness you built. You mentioned you have a few that may be available?
Thanks!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'll take one also.Ok, I’ll let you know after this weekend how many harnesses I have left. I can always get more plugs and do a few more.
DMCTurbo
- Nov 12, 2005
So the canbus/comms connection plugs into the plug which the flasher plugs into correct?
I'll take one also.
Yes. I had to make a splitter for my 2017 with flasher.So the canbus/comms connection plugs into the plug which the flasher plugs into correct?
FYI: I have an updated that I added to the first post.
Update 11/5/24: After further review on our new 2025 EPS Sidewinder, you could reduce the size if the main harness wire to 12ga for main power and ground as well as change the trigger power wire to 18GA. I have updated the attachments.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Thanks Tom.... Not knocking the video, but I can see this is out of my league. Too bad. Brandon (Fords4life) swears by this EPS kit.
I have done 8 installs and 2 more scheduled for December. I’m an expert. LolThanks Tom.... Not knocking the video, but I can see this is out of my league. Too bad. Brandon (Fords4life) swears by this EPS kit.
Doc Harley
- Oct 17, 2016
- Here & there
Goal for the off-season. Thanks, MrSledI have done 8 installs and 2 more scheduled for December. I’m an expert. Lol
Nytro221
- Sep 27, 2015
- Sturgeon Bay
- 08 FX Nytro RTX
How do I get a harness?
I may have an extra one to sell. Depends where you are located or you will have to build your own off the directions above. Message me if interested. I only have one left.How do I get a harness?
I’d build more but would have to have at least 3 people wanting them to make it worth my time to do it.
Here is a splitter that I made if you have a Gap Flasher.
Doc Harley
- Oct 17, 2016
- Here & there
Are you planning on stocking and reselling these?
I have made a few and will make a few more only if I can get a 3-5 order at a time. Or it’s not worth making them for me.Are you planning on stocking and reselling these?
I’d have to sell them for about $50 each plus shipping as well as my full eps & power harnesses are $150 plus shipping.
I know anyone can build them cheaper but I have to do 3-5 at a time to make out on them.
Doc Harley
- Oct 17, 2016
- Here & there
I completely understand your position. Being able to get these harnesses pre-manufactured takes a bit of the load off the entire job.I have made a few and will make a few more only if I can get a 3-5 order at a time. Or it’s not worth making them for me.
Ty...
Right so if we get more interest I’ll make more. Right now I’m out.I completely understand your position. Being able to get these harnesses pre-manufactured takes a bit of the load off the entire job.
Ty...
