He needs all the parts listed in this thread on page one minus harness parts.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
What is the point of the X's in the column of "Common Parts" then? I was under the understanding that those parts were already on the sled and were reused. Is that not true?He needs all the parts listed in this thread on page one minus harness parts.
RobX-1
- Coldwater, OH
See this post from Earthling that put together that Excel document for the reason for using that column.What is the point of the X's in the column of "Common Parts" then? I was under the understanding that those parts were already on the sled and were reused. Is that not true?
I made my own list only what’s needed. I don’t have anything with common parts in the list. Use my list. Trust me I have done 10 of these this year.
Also I’m not even certain on the 22-23 that the harness is there to just plug in. I have not done a model that I didn’t have to make a harness.
BradRR
- Feb 17, 2025
- Fredericton, New Brunswick
- 2017 Arctic Cat ZR9000RR
I’m working on some this week. I’ll keep you posted when ready.@MrSled I would like to be added to the list for the wire harness please. If need be you can pm me. Thanks.
I’ll keep you posted. Might have them all sold but I can get another batch of parts coming.@MrSled, I would also like to get one of your wire harnesses
Farmer 73
- Feb 20, 2015
- 2010 NYTRO RTX SE, 2012 VECTOR, 2001 SXR 600, 2001 PHAZER, 2000 PHAZER, 1983 ENTICER EXCELL III
How is the availability on the main parts from Yamaha? Particularly the Motor, steering shafts and mounting brackets? I am looking to put it on a 2022 Viper LTX GT. On Yamaha's web site it looks like Non available as of now! Does anybody have a source? Thanks for any replies!
Right now I have 2 installs that I need to do and I have 2 parts on backorder for each. They have been on backorder since the beginning of December. 1 is the lower bracket and one is the upper steering shaft. Yamaha has zero and no backorder dates and Cat has backorder dates but keep pushing them out and changing the dates.
Farmer 73
- Feb 20, 2015
Is the motor through cat on back order? I am hoping that if someone buys Cat that the chassis parts that we are in need of will become more readily available.
I received the ones I need. Its all special order and you don't know until you put in an order for them.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I was told by my local Yamaha dealer that all of the Yamaha parts from the list are "unavailable" except for 4 part numbers for some bolts & nuts. They also checked other dealers and there were none available. It appears that Arctic Cat will have some available (at a higher price).I received the ones I need. Its all special order and you don't know until you put in an order for them.
