jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Is the stock 2017 rtx helix stamped 8KC50?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Spec Sheets
Could you guys who recieved your sleds check your paperwork and see if you have the spec sheet? If so could you take a pic and post it here? This is one from a XTX 141. Thanks MTX
ty4stroke.com
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Thanks, lots of info in that post. I can see the part numbers for the helix but still not sure how to identify the helix I have. I don’t see the number that is stamped on it listed in the spec sheets.Spec Sheets
Could you guys who recieved your sleds check your paperwork and see if you have the spec sheet? If so could you take a pic and post it here? This is one from a XTX 141. Thanks MTXty4stroke.com
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Does your helix have a cast finish to the ramps or are they machined where the rollers ride?
All model year 17 helixes are cast finish.
The cut updated helix on later years might have same casting numbers but different markings to identify them.
The updated helixes are listed on here somewhere, might want to do a search.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
My stock 17 helix has those same numbers that you posted in your original post. 35°
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Perfect thanks. I put a newer helix in mine and was trying to detemine if this one was my original.My stock 17 helix has those same numbers that you posted in your original post. 35°
