2019 heavy duty rear axle kits are now for sale.
sabrecat
Vendor
Will fit all Cats, SW and Viper 137 inch track models for 2019. The longer tracks model are still stuck with the trihub.
Same wheels as our Stealth kits have been using but in 8 inch size.
Heavy duty wheels with the larger bearings.
Stock wheels are very cheap and likely will not hold up the studs for long.
Lifetime warranty on axle. $270.00
Will have to call until we get this up on our site
8105450066
Todd
Got mine installed... Really great product. Best part are the wheels use the big 6205 bearings, not the junk 6004's. Second set i've purchased from Todd and are well worth the $270. Cant recommend these enough.
x2
So four wheel kits are for guys who run studs? I'm a Sidewinder newb and my xtx has only two inside wheels. And eightpilot has the coolest avatar ever ;)!
The 4th wheel kits are for added insurance against a catastrophic failure of the tri-hub. If you're an aggressive rider or ride in "boney" conditions , I would recommend adding to, or replacing the original tri-hub.
Sheesh..... I really was thinking 21 large would save me some time in my garage fixing stuff for a couple years. Mine is 141. No fix for that? Sounds like I better get the old Nytro patched up for a spare ride.
