twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Saw this posted somewhere else. Looks like the backend of an SRX.
Sent from my SM-G930V using Tapatalk
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
The only “new” things I noticed are an old Simple 2 stroke style throttle block on the handle bars and extra idlers on the skid. Clearly says Genesis 4 stroke on the side panel and it’s still a procrossWhat I get from the whole teaser video is
New Yamaha chassis powered by a two stroke riding on the Cat suspension.
And it's geared towards racing.
Pete_man26
- Jan 22, 2015
- Yamaha Attak
That is the back end of an SRX, look at the tail light and snow flap. Listening to it a few times over it even sounds like a SRX and when passing by in the video looks to have a trailing arm. I'm betting its a tease of the 2000's SRX against a "new" SRX. New sales pitch "The SRX is back"
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Exactly what it is. Anyone that owned an SRX would know one when they saw it. The new one is a re-labeled sidewinder as an SRX. Note the Yamaha racing blue, blue a-arms etc. They are going to mimic the SRX. As they are saying, undisputed King of the dragstrip. Too bad that's all the other brands see it as, is a dragstrip queen.
Those that don't have 208hp stock, all they can do is badmouth the weight.
What I could see happening is rather than just bold new graphics is offering the 998T as the SRX and the 998NA as the Venom replacing the viper and it's 1049. It may not be this year, as I'm sure they have piles of 1049 engines left to get out. But standardizing on the 998 and 998T would make good business sense. Just like SkiDoo getting rid of the 1200 which they had to pay royalties on. Now they have the Ace 900 and Ace 900 Turbo built on the engine they use in the Spark, Spyder and Can Am products.
If they can get more than 135hp out of the NA 998, it would make the perfect replacement for the Viper.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Like 150-160 hp for a Viper/Apex replacement.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
There are rumors floating around that the new Textron Wildcat XX will be using a massaged version of the 998 N/A that makes 130 HP. I could totally see Yamaha discontinuing the 1049 so they can use one engine in several segments. The Wildcat XX, YXZ, and the Cat and Yamaha sleds could all utilize the same engine. Same with the current turbo. The sxs industry has a 1,000cc limit, which makes the 1049 a obsolete.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
That's not a rumor anymore. It's for sure and the release will be on the 25th with the sleds. They are also going to offer the full 998T in the XX as well in the very near future. That's good business to standardize on limited engines, let alone use it in multiple platforms and multiple brands.There are rumors floating around that the new Textron Wildcat XX will be using a massaged version of the 998 N/A that makes 130 HP. I could totally see Yamaha discontinuing the 1049 so they can use one engine in several segments. The Wildcat XX, YXZ, and the Cat and Yamaha sleds could all utilize the same engine. Same with the current turbo. The sxs industry has a 1,000cc limit, which makes the 1049 a obsolete.
gytr done
- Jan 8, 2015
- Rx1
It is a SRX on the left side, no doubt. But if you look the new model is sitting right beside it in the pic, Behind the glove of the person standing on the right. Plain as Jane. Now is it truly "new" , or just another Y rendition of new.
LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE, Hurricane Tune on the fly
Pilot Skiis,
- Woodbridge, ON
If I had to guess, it looks like they are taking a page out of the Dodge Demon intro.
If an OEM stresses straight line racing with an SRX as the anchor sled at a light tree, I can only assume they are bringing it, such as jamming an Apex like motor + turbo in a Sidewinder like chassis, along with twin tailpipes singing down the drag strip leaving the competition in the snow dust.
They are surely watching the aftermarket tuners (ecu and clutch) and see there's a market for what I would call extreme performance enhancements in the context of sled speeds.
Perhaps Yamaha is not sharing this one with AC.
Pete_man26
- Jan 22, 2015
- Yamaha Attak
Too me it doesn't sound like a apex motor, I know your just suggesting along those lines. What does a stock winder run for boost 9PSI? So I'm thinking it's a NA 998 3 holer that makes around the 160-165hp range installed in the sidewinder chassis, named the SRX.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Yup, rebadged srx...arse end is the same and the blue grips.
I don’t like how it says “final round” on the light tree though....
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
It's a lowered down version of the sidewinder and more than likely will be called a srx, pretty sure its been in the works for a couple of years now. That's my guess, I don't really think they are going back to the pro action with trailing arms but who knows, it probably would work better than the old delta box
theCATman
- Feb 19, 2007
- WI
- Yamaha
Still a shared chassis. Don't get too big of Blue Balls. [emoji23]
I vote SRX, or Venom. 998 N/A 165ish hp.
Sent from my SM-G930R4 using Tapatalk
cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
Wont we know on the 25th when AC does their 2019 release, esp if it is a shared platform?
"The future is near. Witness the reveal of the all-new, industry-changing 2019 #ArcticCat models on 2.25.18."
- 6K
