zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
Hey guys, have a brand new SRX, went up northern Michigan over this last weekend to get a start to breaking it in, since about 3 miles it has this weird air box noise. We have checked all the necessary clamps and everything was tight and good, also changed the BOV with another sidewinder just to see if it was that, and it didn’t change anything. If you guys could please get on YouTube and look up “2021 SRX (air box noise)” the part one was on the trail, the other one is once we got back to the shop and took the air filter off.
Please and thank you
I could not figure out how to copy the link and post it here
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Sorry bud went on YouTube have no clue. I just bought the same sled so please post your findings good luck
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I'm thinking it's the Roll over valve. Take the vent off the top of the oil tank and see it if quits. If it does, its the Roll over valve venting to the airbox, which Is where I believe they vent it to on the newer sleds.
As the engine builds up pressure it vents, then holds, then vents, the Roll over valve is spring loaded so it takes x amount of pressure to open it up. The noise you hear is that venting thru the ROV.
This is the hose I'm speaking of removing to test and see if the noise goes away.
getting-rid-of-the-roll-over-valve.151185
KnappAttack
- Feb 19, 2004
- Welch MN
Oh, and I hope you're breaking it in hard and not easy and by the book...
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
After watching the video I was thinking the same thing. Sounds like mine just louder though.
rla1
- Jan 4, 2015
- saskatchewan
- 2017 sidewinder btx le,2021 mountain max le,2011 apex xtx,2012 arctic cat xf m8
The noise is the rollover valve vented to the air box.Open up the air box lid or pull out the hose from back of it while idling and you will be able to definitely hear that is what it is ,if only for peace of mind .
zxtyler
- Dec 12, 2020
- Michigan
- 2020 SRX
We did figure it out. You guys confirming is awesome! Thank you! We kinda panicked I guess. You know how much these things stupid cost.
sab2022
- Feb 21, 2020
- Maine
- 2023 Sidewinder S-TX GT
Can you please tell on the 2o21 where the roll over valve is? I believe on my 2020 its been moved
WinderFab
- Mar 1, 2009
- Woodbridge, ON
It’s tucked just in front of the steering post, follow the hose from top of oil tank.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Thanks snowcaine for these pics.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
RAMSOMAIR
Wonder why they moved it?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Breaks off when you roll it over...
RAMSOMAIR
Hence the name roll over valve lol!!
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Now thats funnyHence the name roll over valve lol!!
