jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
That would be my fault.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hahaha all good hope you got her fixed upThat would be my fault.![]()
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Nice, I know this is off subject but..
Did you set the offset on that 22 using the hurricane tool?
If you did im curious what number you came up with.
I did not use my hurricane tool on mine(big mistake)
My clutches are all chewed up with a 57.8mm offset.. And the measurement was taken several times.
Sorry for going off track but I know your good at mods and very knowledgeable, but don't assume the offset numbers of the past will work on the 22. Im still trying to figure out mine as 57.8 is way OFF on mine in 110 miles..
Snow all melted, work in progress
Take it in for warranty ?
Did a rivet get in there and tear up your clutch?
When I was done doing my steering bushings I made sure to vaccum out all the old rivets.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
My buddy went to the cat dealership which is only 1 mile away. He inquired about what sealant to use on his 17 RTX motor oil leak. They offered a new sealant for $90, supposedly very thick and much better then the Black silicone that many are using! He bought the Black from them for around $10 he said.I have a 22 srx in for some hurricane goodies and taking a close look for any updates.
I notice they used a harder sealant like loctite 5900?
Definitely a different compound then 17 to 21
View attachment 164433View attachment 164435
So yeah, they have a new sealant for sale!
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
So.....should I install the BOP oil tank gasket I have in the ready or pickup some of the new sealant? I have not pulled the sled out of the trailer yet but noticed what appeared to be a small oil stain in the trailer deck directly below the oil tank. I'm at ~380 miles and yet, I also purchased the oil tank bypass kit. Yes, still in warranty.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
The picture made it look worse then it was. Just hope my center to center and parallel is not crazy out. Chaney lake testing in a couple days.Take it in for warranty ?
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
I just put in the oil tank gasket, i was a bit surprised to see how wide it is and how it folds over when tightening it, but if it works, it works lol.So.....should I install the BOP oil tank gasket I have in the ready or pickup some of the new sealant? I have not pulled the sled out of the trailer yet but noticed what appeared to be a small oil stain in the trailer deck directly below the oil tank. I'm at ~380 miles and yet, I also purchased the oil tank bypass kit. Yes, still in warranty.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
I trimmed some of the excess off after I got it put together and torqued down
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
I resealed my buddies 21 T-Cat oil tank that was leaking. I used the gray GM rtv that they use on there Dura-Max oil pans! Don't know the part# off hand, it's a little pricey but definitely does the job! When I put on a flat bottom oil pan on my 15 D-Max I literally had to get a 2ft pry bar to get the stock pan off the block!
HABS 1
- Oct 22, 2015
- corunna,ontario
that grey rtv i believe is meant for aluminum,flex n torque wise,more durable,pwc gyes use it on the paper part of the 2 piece head on 2sks , works great, but i think if mine develops a leak the bop gasket is the way to go , just need to order it n have handy , sounds like a matter of not if but when that will leakI resealed my buddies 21 T-Cat oil tank that was leaking. I used the gray GM rtv that they use on there Dura-Max oil pans! Don't know the part# off hand, it's a little pricey but definitely does the job! When I put on a flat bottom oil pan on my 15 D-Max I literally had to get a 2ft pry bar to get the stock pan off the block!![]()
Kuzzy
- Dec 6, 2020
- saskatchewan
2022 STX GT
2017 King Cat M9000
i may do that as well, but for now ill leave it as is. It may help identify a leak later, who knowsI trimmed some of the excess off after I got it put together and torqued down
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
What do you guys think about using Yamabond or 3 bond case sealant. I still have some of that from my 2 stroke days.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
HARD NO.
Turboflash
- Mar 18, 2019
- Southern MN
Too thin.What do you guys think about using Yamabond or 3 bond case sealant. I still have some of that from my 2 stroke days.
Mototown
- Sep 11, 2018
- Apex 40 th
My 18 winder never leaked , my 21 leaked after the season was over with the roll over valve replaced from day one . Another guy with a 21 is leaking after the summer.
Going back to the offset from the factory my 22 LE had 1 shim behind secondary was set at about 60.5 . Tested sled in my field, it feels pretty fast stock and pulled right through to 9100 rpm with stock clutching . Better than my 21 srx stock . After checking the clutches I did notice this is the first sidewinder I have had that the secondary rollers have equal pressure on all 3 ramps .
