1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2018 High Country 9000
2001 SRX 700
I was at a 2023 snowmobile show today and opened the clutch side cover on the new SRX. I was surprise to see the helix was stamped 8MA10 on it. Can anyone with a 2023 SRX check if you have a 8MA10 helix on it and mesure it?
Thanks!
Thanks!
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2001 SRX 700
I just checked the part book and it also show that new helix number...
finnpowersports
- Nov 23, 2014
- Northern NY
- '23 SRX LE; '22 Assault 850; '22 Enduro 600R; '23 Rave RE
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2001 SRX 700
I wonder why they changed the number from the 8KC70. Just saw that in part book they are all 8MA-00 or 8MA-10.
stone88
My 21 and 23 have the exact same helix in them 8MA-10.
My 2022 has the same.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
the 8ma-10 is the 33-35 helix, correct?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Look at your spec sheet that comes with your new sled. It gives the helix angle on there.
The helix casting numbers may be the same but these are a machined helix now.
Please post up your spec sheet.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
In the frequently asked questions section posted in the top of the Sidewinder section their is a link for a thread to post your spec sheets.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
My '23 spec sheet says 35-39. Will post later.
ViperSbite
- Aug 23, 2005
- 2023 Sidewinder SRX
2004 Viper S
- Northern Illinois
Attached here for reference-Look at your spec sheet that comes with your new sled. It gives the helix angle on there.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Mine does also. Not sure where I got 33-35 from..My '23 spec sheet says 35-39. Will post later.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
8MA-10 has been the helix spec since 2019, the 8KC70 is actually a 37 degree helix. What Yamaha did for 2019 and 2020 was recut the OEM 37 degree helixes they had in stock to the 35/39 helix angle. Somewhere there was a tech bulletin explaining it.
stone88
mine the sameMy '23 spec sheet says 35-39. Will post later.
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2001 SRX 700
Thanks! Never thought Yamaha had a 37 degree helix. Was that 37 degree offred to the public? Or they were all cut to 35-39?
