The Running Boards are awesome in my opinion. Great grip and no flex. Not sure whether they will hold snow. The Prototype at my Dealership the plastic is painted which looks great. I worry about how the subframe is attached to tunnel at bottom just with two bolts vs ProCross where it’s inserted into tunnel then two bolts. I also worry about the subframe itself. Tubular nytro frames were very prone to bending and they were attached to a casting. Lot of unknowns but that’s what makes the first years so exciting. The risk!
Fast
- Sep 25, 2018
Take a good look at the matrix, looks like a replica of the sidewinder chassie, and i did drive one. There's no comparison to the srx not even closeYour kidding right ? That chasis is so out dated rode my Uncles Matryx a few weeks ago procross is not even close to the same league !
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have driven multiple Matryx chassis and I dint like any of them.
The Turbo 850 was the only one that I think I could ride all day.
I am sure they are fine for some but I just cant get used to the amount of body roll in that chassis.
The new Cat chassis LOOKS to corner flat but only a test drive and some adjustments would reveal the truth.
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
The matrix is a horrible ride, worst of 4. Also have rode one. Wife wanted a 2 stroke went with a skidoo and the ride is night and day better. I still prefer my sidewinder over the xrs for aggressive train.Take a good look at the matrix, looks like a replica of the sidewinder chassie, and i did drive one. There's no comparison to the srx not even close
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Stiffen front shock clickers and run the xcr front springs or a set of dual rates from accelerated or Hygear.I have driven multiple Matryx chassis and I dint like any of them.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
IF they where mine I would HAVE to do something to make them ridable for my preference.Stiffen front shock clickers and run the xcr front springs or a set of dual rates from accelerated or Hygear.
I do know if you run the walker Evans shocks on the stiff setting they tend to break the snap ring that holds the clicker assembly in the reservoir. I have rebuilt a few with this problem. The last customer (friend) that I did this for did in fact go to a heavier front shock spring and I added a little valving to the front shocks also.
- 72K
