Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
I just noticed, LTX GT EPS has same black dual rate springs as lowered Thundercat? I count 11 coils so same spring height as an SRX or Thundercat?
Was it to lower just the front to add ski pressure/bite since it doesn't mater anymore due to EPS? I doubt they would lower the back too otherwise what's the point of SRX.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Cant imagine doing just the front lower? I'm betting the rear on the sled you pictured has the lowered torsion springs.. Or shall I say torsion springs that are "clocked" differently. ALL THE SIDEWINDERS should be running the springs and torsions for a slightly lowered ride!
justinator
My xtx has the srx springs in the front and stock torsions in the rear and all is good. No different really than taking a bunch of preload out of the stock springs minus you dont get the excess body roll with the srx springs
MBOKMAN
- Sep 27, 2021
- SOUTHWESTERN NEW YORK
- 2023 VR1 BOOST, 2022 XCR 850
2018 Thundercat with TD Jukebox header tunes
I'm interested to know if the rear springs are similar to the SRX as well.I just noticed, LTX GT EPS has same black dual rate springs as lowered Thundercat? I count 11 coils so same spring height as an SRX or Thundercat?
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
I checked out the Yamaha models on their website, and the LTX GT EPS is listed as having dual rate front springs, but the non-EPS models (other than the SRX) do not have the dual rate springs. I have ordered an EPS model for my wife, and I am already jealous! It will be awesome if her sled corners as flat as the SRX does. I wonder if the use of the dual rate springs has something to do with the handling characteristics of a sled with power steering vs. one without power steering?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Then again you can get the Thundercat with or without PS...I'm curious if that selection affects rear spring.
We'll find out once the microfiche gets updated with '22 yam 998 engine on either website.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I personally think the gt models somehow have different springs even though they look similar. Only the srx states “low profile srx 137 suspension” as the viper and sidewinder gt’s says slightly lower front suspension.
But who knows, with Yamacats anything is possible lol..
Wannaviper
- Mar 18, 2014
I looked at all the LTX GT models on Yamaha's website, and the Sidewinder with EPS shows dual rate front springs, but the Sidewinder without EPS does not. Then I looked at the Viper LTX GT, and they say it is has the dual rate front springs. It doesn't seem to make any sense to put dual rates on the Viper GT and not the Sidewinder GT, so maybe they just need to work on their website and be consistent?
So, I guess the big question is what would you have to do to your LTX GT to get it to handle like an SRX? What makes up the SRX suspension? Does putting dual rates on the front essentially give you the same front end as an SRX? What would you have to do to the rear skid? Different torsion springs and different shocks, or is there more to it?
MBOKMAN
- Sep 27, 2021
I believe the GT has the same front springs as the SRX. I'd like to know how the rear suspension compares.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Correct, for lower height the SRX has front dual rate and different rear torsion. Which some guys have switched over and posted the result.I looked at all the LTX GT models on Yamaha's website, and the Sidewinder with EPS shows dual rate front springs, but the Sidewinder without EPS does not. Then I looked at the Viper LTX GT, and they say it is has the dual rate front springs. It doesn't seem to make any sense to put dual rates on the Viper GT and not the Sidewinder GT, so maybe they just need to work on their website and be consistent?
What I am more curious is to find out what and why they did diferently with EPS sleds springs front and/if rear. Cause if they run the same SRX spring height up front but with standard rear torsion. Without unbalancing the sled. Then this setup could be applied to people who run BOP PS or snowtrackers as these acts similar to EPS.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
I would suspect the dual rate springs on the GT is for a more compliant ride since it’s ment to be a trail touring sled with the power steering.
MBOKMAN
- Sep 27, 2021
I called my dealer to make the deal on the Sidewinder GT and he said that Yamaha has cancelled all of his in season orders. I hope my 22 XCR snowcheck shows up before the snow.
Wannaviper
- Mar 18, 2014
It will be really sad if there are no Sidewinders available in-season. I suspect that most potential buyers were not willing to commit to a spring order, and Yamaha will lose customers as a result. I wonder if it is a situation where Yamaha didn't have the ability to produce the engines in sufficient quantity, or whether it was AC being unwilling to allocate more time on the assembly line to the 4-stroke sleds? Maybe a little of both?
Wannaviper
- Mar 18, 2014
If the lowering of the SRX is simply due to the dual rate front springs, and a different torsion spring in the rear, it seems like the GT could be a real winner. Put on a different rear torsion spring, and you have an SRX with EPS and a 1.25" track; flat cornering, power steering and more traction sounds perfect to me.Correct, for lower height the SRX has front dual rate and different rear torsion. Which some guys have switched over and posted the result.
MBOKMAN
- Sep 27, 2021
That was what I was thinking!If the lowering of the SRX is simply due to the dual rate front springs, and a different torsion spring in the rear, it seems like the GT could be a real winner. Put on a different rear torsion spring, and you have an SRX with EPS and a 1.25" track; flat cornering, power steering and more traction sounds perfect to me.
