super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Hey guys! First couple rides in my 22 LTX LE. Love the sled but not happy with rear yet. Read a bunch of posts and rear mounting hole is in upper position which should be correct for 22. I read they messed with it on 20-21 and moved it down to compensate for taller spindle position, but ultimately moved it back up. My issue is sled looks like a squatter truck. Rear sits low, and front looks like it’s on Dollie’s when whole sled on flat ground. I do have way more sag then my viper did and I seem to bottom out easy. Running spring adjuster in med with shocks on 2. Steering is not bad with some push in corners. I’ve read to take all preload out of front shocks and check center shock preload. Just not sure where to start especially since Yamaha couldn’t even decide which mount hole was right. I know there is a million different opinions but looking for start point. What did everyone decide on best mount hole ect. Thanks for the help guys.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I would definitely keep it in the upper hole, my 20 came with bolt in lower hole which made steering extremely hard till I cranked the s**t out of the centre shock which killed the comfort of my rear suspension. Ive been happy with moving the suspension to upper hole and Yamaha figured it out too lol..
Post a pic of your sled, it shouldn’t be squatting that low.
super1c
Moderator
- Apr 10, 2010
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
super1c
Moderator
- Apr 10, 2010
Any thoughts on how to fix said squat? By second position I’m assuming your running bottom hole.
hellflyer
- Dec 2, 2008
Nope! Top hole second position on spring adjuster. I think there may have been a spring issue on some of the 2020 where they where weak to begin with. This may be a reoccurrence.Any thoughts on how to fix said squat? By second position I’m assuming your running bottom hole.
Andy
super1c
Moderator
- Apr 10, 2010
Hmmm. I’m set to that now so good start there. What do you think about the front spring pre load? I haven checked close but front is stiff and arms are angle up. Front rode stiff also. Ive only got 200 miles on it so I know it will brake in yet.Nope! Top hole second position on spring adjuster. I think there may have been a spring issue on some of the 2020 where they where weak to begin with. This may be a reoccurrence.
Andy
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Most guys run the a arms parallel, I got mine pretty close by adjusting the front shock springs to no preload.Hmmm. I’m set to that now so good start there. What do you think about the front spring pre load? I haven checked close but front is stiff and arms are angle up. Front rode stiff also. Ive only got 200 miles on it so I know it will brake in yet.
hellflyer
- Dec 2, 2008
What fab said! Lift the front off the ground and back the springs off all the way then tighten the collars until they touch the springs and then 2 turns tighter . That's a good starting point
Hammer Down
- Oct 7, 2016
- Loudon, NH
- Sidewinder STX-DX 2017
Apex XTX 2012
I had same thing with my 2017. Changed rear springs fixed it. Actually replaced with next up stiffer spring I think from 2014 cats. I ride with 4 gal tank and luggage out backHey guys! First couple rides in my 22 LTX LE. Love the sled but not happy with rear yet. Read a bunch of posts and rear mounting hole is in upper position which should be correct for 22. I read they messed with it on 20-21 and moved it down to compensate for taller spindle position, but ultimately moved it back up. My issue is sled looks like a squatter truck. Rear sits low, and front looks like it’s on Dollie’s when whole sled on flat ground. I do have way more sag then my viper did and I seem to bottom out easy. Running spring adjuster in med with shocks on 2. Steering is not bad with some push in corners. I’ve read to take all preload out of front shocks and check center shock preload. Just not sure where to start especially since Yamaha couldn’t even decide which mount hole was right. I know there is a million different opinions but looking for start point. What did everyone decide on best mount hole ect. Thanks for the help guys.
super1c
Moderator
- Apr 10, 2010
Thanks for the help guys, will start her and see what happens!
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Hard to tell by pics but yours does look a little lower than normal, kinda looks like how mine is sitting with some weight on the back. Pic below is with bolts on upper hole, springs on setting 2, saddle bags and tunnel bag filled up with gear and fuel plus the weight of the kimpex connect kit and ice under the tunnel. The sled does look better when the bolts are in lower hole do to the fact that they raised the front end up but it rides better in the upper position.Thanks for the help guys, will start her and see what happens!
TheFarm845
I'm in the same boat, just picked up the exact same sled and the rear end is insanely soft. When lifting up on the rear bumper to fully extend the rear skid, it will drop 3+" on its own when relaxed, and will drag the snowflap when riding it. Shocks and spring blocks are both set on "medium". I called Hauck and they said the crank up the front shock spring in the skid.
acpantera
With a stout rear shock like the one that's in the LTX LE, the gas pressure in that shock should keep the rear suspension topped out all by it's self while at rest with no additional weight on the sled. Perhaps the Fox shock isn't charged at it's maximum' or at all.I'm in the same boat, just picked up the exact same sled and the rear end is insanely soft. When lifting up on the rear bumper to fully extend the rear skid, it will drop 3+" on its own when relaxed, and will drag the snowflap when riding it. Shocks and spring blocks are both set on "medium". I called Hauck and they said the crank up the front shock spring in the skid.
TheFarm845
It sure could be, that was my first thought, is super soft or bad shocks. The sled is still brand new with not even 1 mile on it. I planned on riding Saturday but can't make it to the dealer until Friday afternoon, so I sure hope they can figure it out asapWith a stout rear shock like the one that's in the LTX LE, the gas pressure in that shock should keep the rear suspension topped out all by it's self while at rest with no additional weight on the sled. Perhaps the Fox shock isn't charged at it's maximum' or at all.
- 10K
