stgdz
- Mar 27, 2021
- Buffalo MN
you are going to be running close to 15PSI at 270hp, if not 17 when you eventually get to that tune.Nope!!!
You will need to do the intake spacer mod at that point and since you are in there you may as well do the two upgrades listed. Its 300 bucks more at that point and well worth it.
SledFreak
- Feb 7, 2005
- Ontario. Canada
You dont need the intake mod at 270. 300Plus is where boost leaks. But, its good insurance...
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have to disagree here. I have seen those clamps leak on 240 ss tunes.You dont need the intake mod at 270. 300Plus is where boost leaks. But, its good insurance...
I think anytime you are approaching 16psi you better start thinking about those clamps. It may not happen right away, but over time they develop a leak.
Derek Fosbury
- Jan 18, 2021
- 2022 Sidewinder S-TX GT
2023 AC T-Cat EPS w/ATAC
- Sledding Location - Fenelon Falls, ON
Bit off topic... but what windshield have you used that you would consider the "quietest"? Curious as I'm always looking for the quietest possible rideWith my CKX Mission helmet, the stock muffler, and a good windshield, the sled is whisper quiet.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Food for thoughtI have to disagree here. I have seen those clamps leak on 240 ss tunes.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I like a mid height touring windshield with mirrors. I am sure it takes a few MPH away but I do not hear the wind in my helmet at speed. I agree that quiet is good. Keeping the cold away at speed on a zero day is also a nice benefit. Don't feel the cold coming through my suit with this windshield.Bit off topic... but what windshield have you used that you would consider the "quietest"? Curious as I'm always looking for the quietest possible ride.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Add me to the list, mine leaked from day one with the 240ssI have to disagree here. I have seen those clamps leak on 240 ss tunes.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Mine have not leaked at 270 or 300, let alone 240. All I was saying is that I don't think you need it at 240 or 270, but not a bad idea if you want to make sure 100% that there are no issues.
Doc Harley
- Oct 17, 2016
- Here & there
The issue is more like...."damned if you do & damned if you don't."Mine have not leaked at 270 or 300, let alone 240. All I was saying is that I don't think you need it at 240 or 270, but not a bad idea if you want to make sure 100% that there are no issues.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Doesn't matter which tune you have.
If the tune is built for 91 octane and you are running 91 octane and getting knock protection flashing do the intake spacer mod.
Doc Harley
- Oct 17, 2016
- Here & there
Understood....and I would.Doesn't matter which tune you have.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
How do you know Andy? They can leak and you don't even know it. Boost leak detector wont show it. The engine warms up and the rubber leaks without added clamping force. Boost will always show fine, but they leak like a SOB, heats the intake up something fierce and drops the power. I fought with if for quite a while on a few machines trying to diagnose.
Stock sleds can leak and drop the HP too from leaking intakes even. Its a common issue and why some sleds can't pull much for clutching or MPH.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Maybe, I am just trying to avoid doing it. lol. Maybe, I should do it this summer.
Mike do you see the boost come down in the data logs? I don't have a flasher or have data logging.
Doc Harley
- Oct 17, 2016
- Here & there
Number1kyster, have you considered running TD Max spool 16sm with TD stock mod muffler II?I have the TD Max Spool 16 tune for the stock map sensor. I changed the BOV, the belt(XS825), and the primary spring(because it broke).
Mine runs 16.5-16.8lbs of boost and 9,050 RPM on the trail, 9,250RPM on ice. I've seen 128 on the speedo/123 GPS.
I'd go for the 240 tune if the price difference was that much.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Nope. I don't want any extra noise.Number1kyster, have you considered running TD Max spool 16sm with TD stock mod muffler II?
