Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
So, this line in center is the fuel return? That's the one that goes back to slipper, banana, etc.
Fords4life
- Dec 7, 2021
- South Dakota
Yes, with red fitting.So, this line in center is the fuel return? That's the one that goes back to slipper, banana, etc.
Doc Harley
- Oct 17, 2016
- Here & there
Thanks, bud. Some days I lose confidence in myself....Yes, with red fitting.
Yup...after rerouting the fuel return on my sled I just left a short piece of hose on that fitting and plugged the hose.So, this line in center is the fuel return? That's the one that goes back to slipper, banana, etc.
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
This is what I was getting at in your pump post. That hose connected to the red fitting runs back to the fuel regulator. I have the red fitting as well, and since most say to drill it out, or plug it with a return line, I decided to leave it in place, cut the hose and install a tee. The fuel can then return with the path of least resistance. To me, it didn't make sense to plug this and make the pump return fuel to an area that would have pressure when the tank is full. It would be like running a return hose to the bottom of a full 5 gallon pail. I have never read from anyone that it will cause a problem either. I would also suggest if you do this to connect the center port of the tee to the red fitting as it will be the more restrictive path. That stated, I'm not trying to make big power like some do. The tank vent is the black plug with the clear line coming off the top next to it. Maybe what I did defeats the purpose of the return line by doing it this way, but I haven't had any issue running the tank almost empty.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
makes sense what your saying Clint, as when tank is filled higher than the banana, there is going to be back pressure on the return line, but if tank is vented properly, there will not be any back pressure and would be like filling a tank from bottom ... i did have one episode after doing all the pump return as we all do, i had on one ride, when i got low on fuel i was stalling out on hard decel and hard cornering..... baffled me till i cracked open my gas cap and had a big WHOOSH of vacuum.... then it never did again that ride, soo now instead of plugging the return line to tank i added another vent line up to handle bars with a one way air check valve from amazon.... never have that WHOOSH noise now when taking gas cap off and can go to empty on fuel.
Doc Harley
- Oct 17, 2016
- Here & there
Well ...I fellow member gave me perfect instructions on how to save the outlet hose. And well....I shedded it.
I'm hopeful to get away with 5/16" high pressure fuel line. I'll keep it straight directly from the nipple on the pump to the nipple up top. Thoughts?!?!
Turboflash, Thanks for your insight. This one's the real deal. All metal G/rotor. Positive and negative are not marked. I'm hoping to position it like the stock one and everything is the same?!?!
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
YesSo, this line in center is the fuel return? That's the one that goes back to slipper, banana, etc.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
This is how I did mine
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Here you go for wiring.
Doc Harley
- Oct 17, 2016
- Here & there
Thanks, Tim!!Here you go for wiring.
I just ordered that piece of flex fuel line. Wasn't bad. Be here Wednesday.
Doc Harley
- Oct 17, 2016
- Here & there
Oh my.... Mine didn't come out that nice. Lol. Great work!!!
I believe thats PEFIs fuel upgrade kit...very nice.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
mine was wired like that from TD, ... it vibrated loose one trip and was surprised i never blew up cuz im sure it would arc in side the tank...soo i got the proper dual connector that locks in off amazon and soldered the wires. now i know its safe.Here you go for wiring.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
You can buy a modular fuel pump plug for the whalbro pumps from Amazon. Locks in real good to the pump. Has pigtail wires coming out. I soldered the wires to the original factory pump wires with heat shrink over the jointsmine was wired like that from TD, ... it vibrated loose one trip and was surprised i never blew up cuz im sure it would arc in side the tank...soo i got the proper dual connector that locks in off amazon and soldered the wires. now i know its safe.
