Daranello
Suspended
So witch one would be better for me, I'm 235lbs dry weight (naked) I'm going to suck up the limiter strap, loosen the front springs and adding a 13mm sway bar and a rear cooler to look after the ice problem.
I'm riding a 2007 Attak ER. I ride mostly high speed groomed northern Ontario and Quebec trails.
So what should I do 6.5 or 7.0 with the revalve??
P.S. I will be adding lugage to the back from time to time for 2 day trips so I may need some range to juice it up
