87 big bear 350 no spark
Mike1983
Age
41
Ohio
Yamaha 440
Hey guys I'm new here. Just got a 87 big bear moto 4 350 2wd not sure how long it's been sitting but it cranks over but has no spark tested the stator and pickups found them bad replaced all that replaced coil and plug has had ignition switch replaced previously thought maybe bad switch so unplugged it and jumped solenoid still no spark. Have noticed that it does spark one time as you cranks it and turn .the key on off quickly but other then that nothing any jelh would be greatly appreciated thanks on advance
Update got it to run today thinking a bad switch I plugged the switch back in turned in to on cranked it no fire turn it to the off position and jumped solenoid it had spark so put spark plugs and back in and jumped the solenoid again and it
ran
ran
Sounds like you found your problem. Great job!
that is the problem i had with an 1988 big bear 4x4. new ignition is not wired the same as old from yamaha. in my case it was the tumblers that was needed as old ones piled up so i just took the switch apart and re used the old bottom on it.
Ordered new switch and still the same might have to get one from Yamaha i bought a 12$ one off eBay is there any way to wire in a toggle switch or something lol. Other than that it starts fine with switch off and jumping the solenoid also it charging right, road it for about half hour with no problems.any other suggestions
never dug into the switch farther after i got mine running.
