I found this over on Hardcore sledder
"Track dyno numbers are 117hp on pump fuel and 12lbs boost. 141 hp on race fuel and 18lbs boost. Push turbo, .090 head shim, larger injectors. Was able to get 115.8 mph in 1000' with less than ideal ice conditions "
After the clutching and the 4th injector on my MPI turbo at 12#'s of boost my track HP is almost 144. So these are not getting the same HP/# of boost increases that we were told. at the track I am getting 28 more HP at the same boost #'s. which means crank HP on the push is 201 to my 252. And I am getting more HP at 12#'s with a blend of pump and race fuel 7.5 gallons pump and 2.5 of race to their 10 gallons of pure race gas at 18#'s of boost.
