About to install 2 bender stage II turbos on 2 rx-1s tips??
turbo mark said:
i you get frustrated tuning your sled i know a very reputable yammi dealer near you who has installed many bender rx1 kits. And im sure they can help you get her tuned in.
cool whats the dealers name??
Heres another newbe question. Whats heat soaking the engine?? I assume its something like overheating the engine but I hear the term heat soaked used alot???
A heat soaked engine is not necessarily overheating, but it is running with very high water and oil temps. Also temps of the internal parts of the engine have reached a very high and above normal operating temperature. Risk of detonation are imminent. This is where a good Intercooler, enough octane (read race fuel), along with proper engine and fuel delivery setup becomes critical for the survival of your engine if you continue pushing it.
I always take a break and shut the sled off every couple of passes for usually 10min or so when im dragging. The only time I might have problems with that is running down the lake. I used to run down the 11 mile lake at wot for a few min then back to 3/4 and sometimes back as far as 1/2 then back up to wot for a couple miles. When I get the turbo installed I will be more careful and get off in the powder snow and burp it a couple times before getting back on the hard pack and touching it off again...
One nice thing tho is that you will probably go a lot faster at 3/4 throttle than you have ever gone at wot with the stock sled :-)
