STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Has anyone tried the AC5S 5 position shocks yet?
They seem to be a more affordable shock upgrade than the QS3R's , Elka's and such.
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
I know of a guy who purchased a Catalyst with them and he said they were crazy stiff. He ended up having them revalved.Has anyone tried the AC5S 5 position shocks yet?
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Wonder after revamping if they are a substantial improvement making them a worthwhile upgrade with the added cost ?I know of a guy who purchased a Catalyst with them and he said they were crazy stiff. He ended up having them revalved.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
the 5 positions is appealing. The 3 of the QS3's is not enough for me, especially since 3 is almost unusable.
KRK1
- Jun 7, 2024
- Horseheads ny
- ZR9000
I have an 858 SP and waiting on Hygear to finalize their revalve for the AC5s. Beyond setting 1 the shocks are too stiff and on setting 1 they're not that compliant either especially in the small stutters. Pretty sure they'll be a very good shock once revalved.
Simplespeed
- Jan 8, 2022
I agree that number three position is really valued for the extra heavy rider in the very large bumps.. Longer shock rods and longer springs( more travel ) is the answer but then handling is problematic . So your looking for something between positions 2 and 3 for all around along with more adjustability….can you find that at a affordable lower cost is also part of the problem . Let us know if you find that cause Iam sure alot of us would like to continue to improve ride quality…the 5 positions is appealing. The 3 of the QS3's is not enough for me, especially since 3 is almost unusable.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I will try it stock at first. I do have an Elka center shock/spring I can try also.
The ATAC shocks limit my options for the other 3.
I would probably lean towards a revalve with and eye on being able to use all 3 positions of the current shocks.
Simplespeed
- Jan 8, 2022
I agree maybe a revamped revalue would be the answer for position three…I will try it stock at first. I do have an Elka center shock/spring I can try also.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Considering the weight of a 998 verses an 858, they might be better calibrated for the 998 if they are too stiff on an 858. I was considering one for the front skid shock on my Tcat verses the stock shock. I need to check the length of the shock on the 858 skid.I have an 858 SP and waiting on Hygear to finalize their revalve for the AC5s. Beyond setting 1 the shocks are too stiff and on setting 1 they're not that compliant either especially in the small stutters. Pretty sure they'll be a very good shock once revalved.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I think these might be the correct part numbers for the center & rear AC5 shocks for a 137 skid... but I am not positive.Considering the weight of a 998 verses an 858, they might be better calibrated for the 998 if they are too stiff on an 858. I was considering one for the front skid shock on my Tcat verses the stock shock. I need to check the length of the shock on the 858 skid.
Center Shock - 3704-874
Center to center extended length is 12.49" (317.25mm)
Rear Shock - 3704-870
Center to center extended length is 15.24" (387.10mm)
I think the front shocks are too short based on this: Center to center extended length is 17.28" (439mm)
The stock 129/137 ski shocks are 18.36" long so these AC5S would be an inch too short.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
Thank you for doing the work on this topic. When Arctic Cat begins to operate under new ownership, perhaps the AC5 shocks will be fitted for use on the Thundercat.I think these might be the correct part numbers for the center & rear AC5 shocks for a 137 skid... but I am not positive.
JLR
- Dec 6, 2006
- Winnipeg, Mb
- Currently, 2017 Arctic cat thundercat 2018 sidewinder xtx se 137 precision stage 4, 2025 Yamaha Srx bone stock
That center shock would be an updgrade over the current sidewinder fox possibly
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Possibly....That center shock would be an updgrade over the current sidewinder fox possibly
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
If the information is available, look up the spring rates for the shocks, and match them to stock. If the spring rates are off, the valving is likely wrong as well.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I highly doubt that Arctic Cat uses different valving for different sled models. I think it's more of a "if it fits, it ships" situation.If the information is available, look up the spring rates for the shocks, and match them to stock. If the spring rates are off, the valving is likely wrong as well.
