Wow looks like I actually got a deal. Not!
http://www.yamahapartsnation.com/oemparts/p/yamaha/8fr-23815-00-00/pad-steering
Pays to shop I guess. I am sure the parts people didnt know. I didnt. They even said how it was a crazy price. This should not happen though.
https://www.shopyamaha.com/product/details/mx-style-handlebar-pad?b=Snowmobile&d=3|3
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
I need that part on my viper too. Always thought it looked like there was something missing on top of the bars.
Look what you started SnoNinja!
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Are these the pads you are talking about?
yamahaguy
Ride SAFE
- Apr 20, 2014
Are these the pads you are talking about?View attachment 110187
They sure are, and I need 2 of them also.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Yep, those are it. If you order be sure you use the part no. out of the accessories catalog rather than the OEM part no for a Phazer replacement. Looks like big cost difference for same part.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
Here's what I came up with for a bar pad as I did not like the cut-out in the front of the Phazer pad for the Phazer riser mounted Pod.
Fly Racing Bar Pad, $17.96 from online vendor.
After customization with a blue and orange Sharpie.
I can see the entire gauge above this bar pad without stretching to see over it.
TJ-R
- Jan 28, 2013
- 14 Viper XTX
Nice job guys and excellent idea. I purchased the parts and I'm in the midst of doing the conversion, however I am baffled over the rear tripod and cutting/fitting of the dash plastic.
Question; the rear tripod bar which mounts in front of the gas tank, has both the top clamp and bottom two hole plate welded onto it. It appears both you and snow ninja just drill a hole in the plastic dash piece; were one of the ends of that tripod piece removable? if not how did you get the plastic dash piece over the either of the ends?
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
There is a straight cut in the plastic in front of the hole toward the pod. When you install the instrument panel. You twist the plastic to open the slit and jamb it on. It's tight but it goes on and doesn't hurt the plastic. Look at the instrument panel for a 15 XTX-LE on the Yamaha parts finder and you see the slit shown and the location.Nice job guys and excellent idea. I purchased the parts and I'm in the midst of doing the conversion, however I am baffled over the rear tripod and cutting/fitting of the dash plastic.
Here's a pic
yamahaguy
Ride SAFE
- Apr 20, 2014
Thanks SnoNinja. well said
TJ-R
- Jan 28, 2013
- 14 Viper XTX
Thank you both!!
yamahaguy
Ride SAFE
- Apr 20, 2014
TJ-R, This weekend I am going to have my OEM dash plastic off on my XTX LE, so I could make you a template so you know exactly where to cut the slot and drill the hole for the post. If your interested PM me your address and I can drop it in the mail Monday. Hang on to the template so if someone else needs it you can pass it along to the next guy doing this conversion
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
TJ-R, This weekend I am going to have my OEM dash plastic off on my XTX LE, so I could make you a template so you know exactly where to cut the slot and drill the hole for the post. If your interested PM me your address and I can drop it in the mail Monday. Hang on to the template so if someone else needs it you can pass it along to the next guy doing this conversion![]()
Or you could make it a printable PDF which anyone could download from this site?
Birkebeiner
yamahaguy
Ride SAFE
- Apr 20, 2014
Birkebeiner
Well when I did the first one on our XTX SE I ordered the AC kit and it came with a paper template for drilling the hole. There was no good way to align it so it so I threw it in the trash and then made a extract fitting template using our XTX LE plastic and 2 inch wide masking tape then pealed it off and transferred it the other other dash . Would the sizing change after scanning and then reprinting??
birkebeiner
- Jul 27, 2009
- Norway
- Norway
If transferred to let's say A4 size paper and scanned, if printed at 100% it should be the exact same size. But you could add measurements to the template so the person who prints it can double check the measurements.
Birkebeiner
Birkebeiner
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
The other option is to order the 2015 XTX-LE instrument panel. It will have the hole and slot in it in the right spot. I ordered it but they sent me the XTX-SE one with no hole
. I now have a spare in case I ever wanna put it back to stock. That was my goal anyway, I just thought it would be easier to drill for the seat switch and teather in the XTX-LE panel rather than drilling my LTX-LE panel for the tripod.
Six of one, half dozen of the other I guess.
Easy enough to drill.
. I now have a spare in case I ever wanna put it back to stock. That was my goal anyway, I just thought it would be easier to drill for the seat switch and teather in the XTX-LE panel rather than drilling my LTX-LE panel for the tripod.Six of one, half dozen of the other I guess.
